I need to do a head gasket on my m42, Can anybody recomend me a full gasket set at a good price. Links would be great as Im finding a wide range of things from ECP with no pic's to individual items.
M42 head gasket
Scruffymurphy
All you need is the head gasket, the bolts and the front rubber profile gaskets.
Elring gaskets are good quality. Any decent motor factors should be able to get them. Not sure if you can get the profile gasket outside BMW. You'd be best getting all the gaskets from BMW though, less chance of oil leaks later.
Andyboy
- Alpina Colada
If it's overheating and pushing water out, look for cracks in the head from nos 2 and 3 cylinder exhaust valves to the waterways.
bumpygt
Grrrmachine
- E30 Zone Wiki / Team Member
The common leak at the front isn't the head gasket, it's the profile gasket:
http://www.e30zone.net/e30zonewiki/inde ... ile_Gasket
Scruffymurphy
As above it's the profile gasket, but it's still a head off job to fix it.
bumpygt
