retro fit a rear blind??..
kangman
my 2dr has not got one, i think there cool. would i need to replace the rear parcel shelf? or does it rest on top of the shelf?
polsta
whole shelf + 2 clips ,easy to do and adit always has a stock of shelves
TPS
You'll have to take out the rear seat, its a reasonably easy job.
be sure to locate the top clips in the correct recesses .
+ a yard full of scrap turds
kangman
is that a tricky job?magpie wrote:be sure to locate the top clips in the correct recesses .
Duke137
No but if you put them in the wrong place you will ruin your headliningkangman wrote:is that a tricky job?magpie wrote:be sure to locate the top clips in the correct recesses .
clipper
I fitted my blind before the summer but still haven't plucked up the courage to try to fit the clips!
Topblag
the clips press in to a recess on the roof. You have to cut the headlining a little bit to get them in. There's a picture which used to be in the wiki (IIRC) which shows you how to locate the recesses.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Did you get an engineers report or whatever?clipper wrote:I fitted my blind before the summer but still haven't plucked up the courage to try to fit the clips!
Shagging blind rear shelf with hifi pack speakers FTW and it is for sale !
Topblag
Perhaps an opportunity to bundle the clips with the blind to provide a one stop solution.pacerpete wrote:Shagging blind rear shelf with hifi pack speakers FTW and it is for sale !
What does an unopened rear blind equate to in dogging communication protocols ??
kangman
if you got one id be interested...pacerpete wrote:Shagging blind rear shelf with hifi pack speakers FTW and it is for sale !
adit
steve_k
Whats the going rate for these?
prices on ebay are all over the place.
Best solution for the clips in the roof is to fit the parcel shelf blind in place, then pull the blind up and you will see where the tabs at the top of the blind pole go to on the roof lining. If you then have a feel with your thumb by pressing it against the roof lining, you will feel where the recess is on each side.
Check this at least twice as there are 2 recesses near each other and you don't want to cut the roof lining in the wrong part.
bimanut
+1steve_k wrote:Whats the going rate for these?
Topblag
Tart.
