changed instrument bulbs but still dim?
cherryredbenj11
As above, my cluster wasnt lighting up properly, one side was dim other side was out, replaved the bulbs, both side now work but both are as dim as before. any suggestions?
jmc330i
Twist the headlight switch?
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Duke137
This, turn the headlight switch clockwisejmc330i wrote:Twist the headlight switch?
cherryredbenj11
Heres me thinking there should be another switch lol.
rskools
What bulbs did you change as I have the same problem cheers?
Cluster is lit by two 3W capless bulbs. These are fitted into the two larger bulb holders visible on the back of the cluster.
Be sure to replace them with the correct 3W bulbs, as the more commonly available 5W version of these WILL melt the plastic coloured domes and light guides.
