1990 Zinnobar Red Non Sunroof -Heckblende Fitted and Paint
Post Sun Sep 02, 2012 10:25 am
Just had my next e30 deliverd this morning, its a 320i shell with a b25 lump complete with no sunroof.
The car itself is in really good nick, its had a full respray a few years back so the paint is really shiney and not the usually faded heap of shit.
its had the footwell jacking pads welded up to a high standard other than that its fairly original, some rust coming through on a lower arch on the passangers side.
Needs alot of time with bits of trim etc as alot of trim has been off and put back on half heartedly, the pop outs have been robbed and the normal windows put back in, again needs finishing off. clips from front grills missing etc, all just simple jobs
Car even comes with 6 month tax and 3 weeks MOT.
Bad part is it needs a clutch master cylinder and sump, both of which i have. Needs a new drivers seat too as its had the fatty treatment.
Plans are to remove the smoked lights, fit chrome kidney grill and black door handles, and fit some 15" bbs, i have a perfect set which were refurbished a couple of years back, should set it off a treat. Also want to paint the lower half of the rear valance black like its suppose to be.
Other than that i think its a good buy :D
bigredbmw
Zone Supporter
Post Sun Sep 02, 2012 10:58 am
popouts werent robbed alex they were returned to the rightful owner which should of been done before it was put up for sale tbh m8 .......
but you have a solid shell and a very nice car there just needs a little bit tlc and will be sorted
Post Sun Sep 02, 2012 11:13 am
Looks like a decent base for a project Alex 8)
Dan320is
Post Sun Sep 02, 2012 11:50 am
That shouldn't take much to change to your tastes Alex, nice buy. Is it a keeper?
Post Sun Sep 02, 2012 12:58 pm
It is a keeper i hope :D
Post Sun Sep 02, 2012 5:04 pm
good purchase alex ,you'll need to find out why the windows only work with the doors open :?
when you find out what's needed here then the heater blower will probs come back on again and whatever else isn't working inside the car,it'll all be linked to one problem.
or at least i'd like to hope so .
tech1 spoiler winkeye
Post Sun Sep 02, 2012 5:22 pm
It Is one problem and it's linked to the k7 or k1 (can't remember) unloaded relay and a wire to the starter motor.
Check out the wiring diagrams in the links section
jaymos
Post Sun Sep 02, 2012 8:24 pm
Alex every time I come on here you have a new e30. :teehee:
retroboyo
Post Sun Sep 02, 2012 11:25 pm
I like it, what wheels are on it at the mo
harry_p
Post Mon Sep 03, 2012 7:43 pm
Yay, zinno :D
i didnt even know they did zinnobar on a facelift tbh. looks like it should be quite easy to tidy up 8)
cheers,
harry
Curr946
Post Mon Sep 03, 2012 7:49 pm
if its had an engine change I would check the wiring at the starter first. looks a decent car though well worth the money
If your wife must learn to drive, don't stand in her way!
Post Mon Sep 03, 2012 8:56 pm
Thanks for comments, not worried about the wiring just yet, need to spend a fortune on small clips and things at bmw as so much of the trim is missing or not clipped on properly all over the car :( things like this really annoy me
The wheels are some 14" replica bbs things, they're coming off possibly tomorrow have a set of almost perfect 15" bbs had the refurbished 3 years ago.
fitted a new sump with new gasket today, was fiddly removing the old sump gasket but some small blades made it easy work, used very small amount of gasket paste too just to be on the safe side.
Fitted a brand new mushroom gear knob with tri stripe and new gear gator today aswell, cost about £15 for the lot posted from bmminiparts, i know its wrong but i love it :D
the black grill has been took off aswell looks millions better
Post Wed Sep 05, 2012 8:11 pm
Bit of an update
Got new clutch master and slave fitted and now moves under its own steam once again :D
Major interior clean started
wet vac'd the whole carpet seats and cloth bits on door cards, dash and door cards all scrubbed with car wash and a scrubbing brush then had a coating of trim gel afterwards.
Council Shot
Engine Bay
Fitted my 15" bbs today too, looks so much better, the wheels were refurbished 3-4 years ago and still look like new could do with a clean when i get round to it
retroboyo
Post Wed Sep 05, 2012 8:26 pm
Looking very smart now, your cleaning efforts have inspired me to give mine a good clean
Post Wed Sep 05, 2012 8:28 pm
Thanks, every e30 i have has to look like brand new inside, makes it a so much nicer place to be in :D got a 2 year old tech 2 wheel to go in it aswell which will set it off nicely :D
retroboyo
Post Wed Sep 05, 2012 8:35 pm
It's a car to be proud of, I will look forward o seeing any updates
Post Wed Sep 05, 2012 8:36 pm
that battery looks familiar :)
Post Fri Sep 07, 2012 6:38 pm
magpie wrote:that battery looks familiar :)
Does it come with a warranty its fooked winkeye winkeye
Post Fri Sep 07, 2012 9:50 pm
i used to drive the calypso turd up the drive in 1st gear,engine not running but off the cranked starter motor with that battery,it was brand new 4 mths ago.no wonder it's f00ked :D
EDIT......
Those wheels :thumb:
Post Sat Sep 08, 2012 6:44 pm
I will get a new one before the pod think the genuine bmw one off the touring is buggered been flat for months :(
Kedge
Post Sat Sep 08, 2012 10:22 pm
Nice work Alex, love how clean you get interiors. Are those wet vacs expensive?
Instagram - Kedge85
bigredbmw
Zone Supporter
Post Sat Sep 08, 2012 10:28 pm
looking good .nice and clean inside
Post Sat Sep 08, 2012 11:55 pm
Kedge wrote:Nice work Alex, love how clean you get interiors. Are those wet vacs expensive?
Not sure its my mums :D
I bought that hand tool for it however, think it was £120 however its about 5 years old or so. Probably get them alot cheaper now
Picking up some new springs and front struts tomorrow as its on cut springs and one shock is leaking. worst handling e30 ive ever driven if i'am honest 8O
Post Tue Oct 09, 2012 7:08 pm
Got some Genuine E30 Style 10's for the turd, they're in pretty good nick, with 4 good tyres. Some people may not like them, but i like to be different and think they look good.
I also fitted some pop outs back in again.
after removing the number plate surround to fit my heckblend i found some surface rust which i ground down till it was shiney again and painted with zinc primer, will get some zinnorbar red on there before i put the heckblende in properly, i also need 2 new number plate lights as both were cracked.
test fitted
Also found this, cant be good :/ any suggestions ?
retroboyo
Post Tue Oct 09, 2012 7:46 pm
We need Brianmoooore 8O
johnl320
Post Tue Oct 09, 2012 8:02 pm
Fuel tank breather, comes to an end under the bonnet anyway, unless there is a carbon cannister fitted which is very unlikely
Post Tue Oct 09, 2012 8:07 pm
Ah right, is it not fuel return line ?
Will it fail the MOT ?
Kedge
Post Tue Oct 09, 2012 8:23 pm
The fuel feed and return pipes are the two thicker ones to the right and run in the same clips as the brake pipe.
MOT man might not like it, not sure. If I was you I'd cut it back at the tank end and remove everthing from there forward and then just fit a short bit of rubber pipe by the tank to vent there, this is how it is set up on the prefacelift cars.
Instagram - Kedge85
Post Tue Oct 09, 2012 8:25 pm
Sounds like a plan, least its nothing important :mad:
Post Tue Oct 09, 2012 8:30 pm
Is that just the breather pipe to the front of the car ?
They're about £20 from BMW IIRC
johnl320
Post Tue Oct 09, 2012 8:36 pm
I got an advisory for a corroded one so did what Kedge has posted
Post Tue Oct 09, 2012 9:19 pm
Kedge wrote:If I was you I'd cut it back at the tank end and remove everthing from there forward and then just fit a short bit of rubber pipe by the tank to vent there, this is how it is set up on the prefacelift cars.
+1 that's how early turds are,
Rtaylor2208
Post Tue Oct 09, 2012 9:43 pm
Alex is that not the breather pipe to the fuel tank? Can't really tell for sure from the picture, is it snapped or missing altogether?
Rtaylor2208
Post Tue Oct 09, 2012 9:44 pm
Ah too slow
Tan91
Post Wed Oct 10, 2012 4:49 pm
This is a nice turd! loving the Tech1 spoiler as well. Brilliantrot?
Have you done a fair search for rust?
All in all liking it so far and the soap for interior good work, looking pretty mint inside!
