When you fit wheel spacers, how do you centre the rim?
Ceeman
Post Tue Dec 06, 2005 9:19 pm
I have just had a Wilwood disc/caliper conversion fitted and it does not fit behind the BBS without a spacer.
The problem i have found is that a spacer stops the wheel self-centering on the hub, i have done it by eye but is there a better solution?
Any suggestions welcome. :wink:
TOURINGDADDY
Post Tue Dec 06, 2005 9:21 pm
you'll need bolt in spacers that have a hub center on them . there sold in pairs and cost bout 40 bob a pair but u pay for a quality product
astondg
Post Tue Dec 06, 2005 11:02 pm
That's correct ^ . If you get the right spacers (or maybe get some made up for your car and wheels) the centre of the spacer will fit the wheel perfectly and you won't even need those plastic or metal ring things. That is how my spacers are and the wheel fits perfectly and becuase the spacers have the studs it is easier to fit the wheel becuase you can rest it on the studs and you don't have to line up the holes and get the bolts through while holding the wheel.
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
Ziggy
Post Tue Dec 06, 2005 11:29 pm
If you're searching for them, they're usually referred to as "hub-centric" :thumb:
Ceeman
Post Thu Dec 08, 2005 1:47 pm
Thanks guys........i will go hunting for them winkeye
garyp_E30_325i
Post Thu Dec 08, 2005 2:08 pm
There's loads of choice out there; FK, Eibach and Delta all make 'em plus the bespoke options, here's an example:
http://www.performancefx.net/wsbmw.htm
http://www.performancedriven.co.uk/shop ... ?CatID=121
The FK ones look quite pricey but I'm told they're good quality. :?
In saying that it's the Delta spacers I have and they've been fine. :D
'89 325i - was an SE but not anymore, was bronze-beige metallic (yeuch!) but now techno-violet (thankfully)
'89 Toyota Corolla GTi-16 - track, hillclimb & sprint car (yeeha!)
'08 Buell XB12Ss - American engineering at it's 'best'... good fun though
TouringMatt
Post Thu Dec 08, 2005 11:00 pm
What width spacer is it?
Ceeman
Post Thu Dec 08, 2005 11:19 pm
About 5mm :x
