m50 Sump
Lurch320i
Fri Aug 31, 2012 9:24 pm
Hi guys.just a quick and easy one.are the sumps from e34 m50 powered cars the same?ie 2.0 and 2.5 as i have a 2.0 Sump and pickup etc. Would this work?
Fri Aug 31, 2012 9:33 pm
Yep, you doing a conversion?
Lurch320i
Fri Aug 31, 2012 9:56 pm
Yeah im thinking about it.i have an m52b28 spare and the 2.0 m50 Sump etc.just wondered if i needed anything extra i didn't have
darcy
Fri Aug 31, 2012 11:15 pm
Don't forget the oil pickup. Dipstick and tube from the m50 too
Lurch320i
Sat Sep 01, 2012 7:52 am
Yeah Ive got that thanks.Ive got the whole 2.0 engine incase i need any other e34 specific parts
Ive had a look at alot of build threads and the only thing putting me off is either moving the servo or getting a smaller one.surely additional power will require bigger and better brakes so im a bit uneasy about that.
Im in no big rush.its a spare engine and just a scrap car i saved from the junkyard.just playing around with ideas as im trying to build an m20 turbo too
cheers guys
Sat Sep 01, 2012 9:19 am
The clio servo is as good as/better than the E30 one, remember the E30 servo is 20 years older tech
Lurch320i
Sat Sep 01, 2012 11:51 am
Suppose that's true.and the pics clip one just bolts straight up?what if i wanted to run a set of four pot calipers i have to make it stop better?wouldn't the smaller servo exert less force?
Lurch320i
Sat Sep 01, 2012 12:03 pm
bimanut
Sat Sep 01, 2012 6:35 pm
The clio servo does look as if its too small at first glance compaired to e30 one but the clio one is deeper.
It`s nearly a straight swap except that the hole for the clevis pin needs opening up and the link rod will need slight adjustment.
I and probably 90%+ of others have the clio servo,with no i`ll effects if anything i`d say it`s better than the e30 one i had.
Four pot calipers will also be good,many already have them. :)
Lurch320i
Sat Sep 01, 2012 9:08 pm
Excellent that's great news.thanks for the replies and good honest comments.
Now i just need to take the car to my workshop and rip the old m40 donk out to make room!would anyone recommend any mods to do as the engine is out as im already going to replace the rack with the e36 item
thanks again
