Why does m20 not run up to correct temp.
ah
Post Wed Aug 29, 2012 5:26 pm
It occasionally runs at 11-12 o'clock position at stand still,but start driving and it drops to 1/4 or just under,yes I put a new stat in.It runs lumpy and juddery generally but seems to improve when it reaches correct temp.Could it be I have an air lock in the system?
**BANNED**
Post Wed Aug 29, 2012 5:37 pm
Sounds about right to me,anywhere between the three white marks can be regarded as normal.
Youth is wasted on the young.
pnd
Post Wed Aug 29, 2012 5:46 pm
maybe running an oversized rad.
**BANNED**
Post Wed Aug 29, 2012 5:59 pm
pnd wrote:maybe running an oversized rad.
This should'nt affect overall temperature at normal road speeds,but increased capacity to the cooling system will help maintain proper temp levels.
BenHar
Post Wed Aug 29, 2012 6:25 pm
Six cylinder cars use an 80deg C thermostat and run at just above the first quarter mark.
Four cylinder cars use an 88deg C stat and run at about the half way mark. (Dunno what it is for the M3.)
If yours is going up to half way when stationary the viscous coupling on the fan may be getting tired.
Ben
Morat
Post Wed Aug 29, 2012 8:55 pm
My 325 runs bang on half way, but there is variation because the gauges are pretty sensitive.
Post Wed Aug 29, 2012 9:16 pm
If its not running right when cold (or until it reashes temp) I'd say a faulty temp sensor is likely.
But that wouldn't explain it running cooler until at rest. Fan clutch stuck on?
BenHar
Post Fri Aug 31, 2012 3:40 pm
Morat wrote:My 325 runs bang on half way, but there is variation because the gauges are pretty sensitive.
You've probably got the wrong thermostat in it.
Ben
e30den
Post Fri Aug 31, 2012 7:07 pm
Ben
Halfway is bang on , well actually its my e46 that runs halfway the e30 runs at 11 oclock and that after a spirited drive :)
