M20 starter facelift/preface Question
blackE30indy
Post Sun Aug 26, 2012 7:26 pm
Hello all,quick question,
Is a preface starter the same as a facelift,
On m20 engines,I know the solinoids are different,
But are the pinions different,can I run a facelift starter on a
Preface flywheel?
Indy :D
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Aug 26, 2012 7:36 pm
They're different because of the different ring gears on the flywheels. Therefore incompatible.
blackE30indy
Post Sun Aug 26, 2012 7:37 pm
Can I just swap a facelift solinoid on to a preface then ?
blackE30indy
Post Sun Aug 26, 2012 7:47 pm
Only reason I'm asking is,I've bought a complete engine setup,and it was running a preface loom,with the megasquirt wired together,I've sold that on,and now I am running a facelift loom with vems,
So I can just swap to a facelift starter,and it'll crank over fine :D
blackE30indy
Post Sun Aug 26, 2012 7:51 pm
Sweet,cheers for the replys guys :D
Kedge
Post Sun Aug 26, 2012 8:06 pm
I'm still running my pre-facelift starter will an M1.3 loom.
Instagram - Kedge85
blackE30indy
Post Sun Aug 26, 2012 8:07 pm
We're have you put the wires to then mate
Kedge
Post Sun Aug 26, 2012 8:18 pm
Can't remember exactly without looking at the car but I'm pretty sure that they can only go on the appropriate threads due to the size of the ring terminals.
Instagram - Kedge85
blackE30indy
Post Sun Aug 26, 2012 8:20 pm
I'm guessing you've not put any wires on the spade terminals
Then
Kedge
Post Sun Aug 26, 2012 8:26 pm
Its not got any spade terminals :?
Instagram - Kedge85
blackE30indy
Post Sun Aug 26, 2012 8:32 pm
hmm,my preface starter has,if I remember
