Post
Fri Aug 24, 2012 7:17 pm
The question is a bit confusing, (how to convert M42 to run with a cat?), as you later say it out of a 1998 Z3, which would already run a cat as standard (and probably be M44).
Anyway, to answer the second question, none of the M40 exhaust at all will fit, i tried when i did my M40 to M42 conversion (i also have an L reg touring). The front section is the wrong shape and the bore size is much to small to weld or join it to any of the M42 exhaust.
To get around the mot situation, as said by others, you can test emmisions to the age of the engine if its older. Its up to you to prove this. So if you arrive for the mot armed with a "recipt" from a scrapyard/ebay seller/vehicle recyclers, or a letter from a garage saying you have been supplied or had fitted an engine from a 1990 318is, i doubt they wouyld query it (I wouldn't!).
