Educate me?
reepers13
Post Sun Aug 19, 2012 10:52 pm
Coilovers for e30 setup?
Fronts use traditional collies right
But on the rear the spring is seperate so is it then a shock/coil setup?
Or are these eBay kits coilovers on the rear too ie fully heigh adjustable?
My aim; drift use, camber caster and toe adjustment.
Solution; convert to e36 setup? I'd rather keep e30 if I could
Post Sun Aug 19, 2012 10:57 pm
you wanna fit ebay coilovers for drift use?
ross_jsy
Post Sun Aug 19, 2012 10:58 pm
Depends, cheap nasty eBay coilovers use a separate spring with an adjustable spring perch. Procier coilovers use a traditional set up and mount on the shock absorber mountings
reepers13
Post Sun Aug 19, 2012 11:46 pm
Bc collies use what setup?
polsta
Post Sun Aug 19, 2012 11:51 pm
theres a set for sale on here for 300 notes
reepers13
Post Mon Aug 20, 2012 12:51 am
polsta wrote:theres a set for sale on here for 300 notes
Ooo where?
harry_p
Post Mon Aug 20, 2012 3:11 pm
there's nothing wrong with the separate spring and damper setup, if done properly. just a lot of cheap generic kits can't seem to get their head around it and you end up with a bit of a missmatch.
decent companies still seem to be able to make the separate spring and damper locations work fine.
at the front, because of the way the front strut is made, cheapo coilovers will just use and adjustable platform and a cone shaped spring on top of the standard spring perch (a bit like the rear end setup) more expensive kits will come as a complete strut with traditional threaded collars, but you'll often need to send your old struts in to be modified.
if you don't want the expense of a 'proper' front setup, and can (or know someone who can) weld, you can buy threaded collars and get them welded to your existing struts, so you can then use traditional style collars and springs, with the damper of your choice.
the e36 front setup has the advantage of the damper bolting to a separate spindle, so theyre generally cheaper and easier to get hold of off the shelf. it does mean needing to change a lot of other bits too though!
cheers,
harry
polsta
Post Mon Aug 20, 2012 3:23 pm
Ooo where?
not coilovers gas struts but may be suitable ?
http://www.e30zone.net/modules.php?name ... c&t=224897
Post Mon Aug 20, 2012 7:13 pm
Isnt it about time the differs started welding dampers up solid at the required drop? Its got to be better than useable suspension surely? After all, the tyre has plenty of 'give'
innit
shanehaward
Post Mon Aug 20, 2012 8:10 pm
i dont plan on keeping my ebay coilovers forever, they were only ever ment to be temporary, but...
ebay coilovers = £200
brand name = £800+
ive had a mk3 vr6 with cheap coilovers and had another vr6 with kw coilovers and they both handled almost identical. I know kw's etc are better made and will last longer but i would choose ebays over lowering springs and shocks anyday of the week and they proberly work out cheaper too if you buy new.
(p.s. i do plan to get kw's/gaz etc.. in the future but only for kudos) :wink:
Demlotcrew
Post Mon Aug 20, 2012 9:06 pm
DanThe wrote:Isnt it about time the differs started welding dampers up solid at the required drop? Its got to be better than useable suspension surely? After all, the tyre has plenty of 'give'
innit
Innit! :D
reepers13
Post Tue Aug 21, 2012 7:54 am
thanks for the replys.
i had some cheapo ebay collies on my 36 328i that came on the car like new, but very soft and for drifting not what i want.
daz do collies for £650-700 dont they?? i dont mind spending decent money on something like this but if i am id like to have traditional rear collies.
please educate me with this 51mm front strut thing. mines a H reg 325i non sport. but has sport suspension there at the min
harryP - i know a good welder, actually the car helping build the car so any more info on what your refering too or point me in the right direction.
sorry for all the q's kind of new to e30's (although had a 325 about 8yrs ago but not for this drift stuff :p)
ross_jsy
Post Tue Aug 21, 2012 8:03 am
http://www.raceperformancemodified.com/ ... ilover-Kit
Why must you have a set of coilovers on the rear?
And you will already have 51mm struts.
reepers13
Post Tue Aug 21, 2012 9:47 am
ross_jsy wrote:http://www.raceperformancemodified.com/ ... ilover-Kit
im not saying MUST.. im saying if im paying good money like £700+ then id expect rear coilovers.
what are bc racing ones like?
Morat
Post Tue Aug 21, 2012 10:03 am
But why coilovers? There's nothing wrong with springs and shocks....
reepers13
Post Tue Aug 21, 2012 10:19 am
Morat wrote:But why coilovers? There's nothing wrong with springs and shocks....
im coming from a history of jap cars and i swear by coilovers. i guess thats my reasoning. if an e30 will handle as good with seperate springs then ill consider it
but when it costs more to have rear coilovers on an e30 im presuming your payng a higher premium for a reason?
Morat
Post Tue Aug 21, 2012 10:26 am
It's just that the suspension design of the E30 doesn't lend itself to coilovers as easily as some others. If you get conventional coilovers at the rear your putting loads through the shock towers that they were not designed to cope with so you'll need to do work to reinforce them.
If you want to do that, fine - it's up to you. But a decent set of shocks/springs works well if you're happy to live with the "set it and forget it" nature of the setup.
Camber isn't adjustable on the E30 as stock. For the front you can use adjustable top mounts, for the rear you need to weld tabs onto the rear beam and use wiggle bolts. A quick search on here should show you what you're looking for.
this thread should be useful
http://www.e30zone.net/modules.php?name ... ber+adjust
Demlotcrew
Post Tue Aug 21, 2012 10:56 am
E30 rear can handle coil over damper design quite adequately, I track my car hard on very stiff springs, no issues at all, in fact calculations have shown the stock panel being able to handle the loads.
Of course if we go in to the DTM realms then yes the rear turrets need reinforcements for sure.
reepers13
Post Tue Aug 21, 2012 11:52 am
Morat wrote:It's just that the suspension design of the E30 doesn't lend itself to coilovers as easily as some others. If you get conventional coilovers at the rear your putting loads through the shock towers that they were not designed to cope with so you'll need to do work to reinforce them.
thanks
ive got a fully poly bushed rear subframe ready to go in with full camber ond toe adjustables, also reinforced lower arms
i want a stiff setup for the rear but couldnt find any solid bushes for it
whats a decent rear suspension setup then? ive heard the spax rsx are quite good but then these are not collies up front correct??
height adjustment and damper soft/hard adjustment are very important to the setup.
reepers13
Post Tue Aug 21, 2012 11:55 am
spring rates also important as running m60b40
Demlotcrew
Post Tue Aug 21, 2012 12:14 pm
thanks
Im running AST race, £2200 + VAT and full rear dual rate coilover, extremely light as its made from billet aluminium which is then case hardened to 25 microns.
Post Tue Aug 21, 2012 1:43 pm
Will you be reinforcing your quarter panels Andrew? :D
Demlotcrew
Post Tue Aug 21, 2012 1:59 pm
No not really DanThe, mines are completely rust free :wink:
reepers13
Post Wed Aug 22, 2012 7:59 am
im leaning towards bc coilovers now
spoke to a uk seller who can get me custom spring rates, i was thinking 10kg all round for a nice stiff setup with the m60b40 upfront.
any thoughts on this?
thanks
Demlotcrew
Post Wed Aug 22, 2012 8:35 am
10kg rear non coilover?
reepers13
Post Wed Aug 22, 2012 9:43 am
Demlotcrew wrote:10kg rear non coilover?
Correct
Demlotcrew
Post Wed Aug 22, 2012 11:21 am
I dont think I can help, I'm not too clued up on the balance ratios of an inboard spring arrangement, in very basic terms 10kg inboard rear should be good, but I dont want to say for sure without knowing.
reepers13
Post Wed Aug 22, 2012 11:47 am
well bc lists 6kg for an e30 so 10kg should be a vast improvment i would have thought
Demlotcrew
Post Wed Aug 22, 2012 12:22 pm
The problem is the lever ratio for the back, I don't have the figures to reverse engineer from true rear coilovers to inboard spring arrangement.
Generally speaking you want to have a loose rear end and a grippy front end that doesn't scrub off speed in the bends (this is for drifting). One way to get this is to make sure the beam is solidly mounted to the chassis and the other way is with high spring rates. But there are a few other considerations to be made, such as camber, weight and wheel/tyre width/choice. For a well balanced track car, the general rule of thumb with true real coilovers is the rear spring rate is roughly half the front, but with in board springs its very different, hopefully someone else will be able to help you.
reepers13
Post Wed Aug 22, 2012 12:48 pm
Demlotcrew wrote:The problem is the lever ratio for the back, I don't have the figures to reverse engineer from true rear coilovers to inboard spring arrangement.
thanks,
normally the front should be slightly softer to avoid the understeer, these bc come with adjustable top mounts for camber and stiffness.
the rear is spring and shock set up but i know nothing about this
i have a rear subframe that has the camber/toe plates with bolts and the trailing arms or lower arms whatever you call them have had a strengthening bar welded to avoid and flex in them.
wheels initially will be 9.75x17 et25 with a 20mm adapter spacer thus giving an et5
ps for drifting you want as much grip as possible at the rear and front... to lose traction you play with tyre pressure but i will want to run no more than -1 camber rear and -2/3 front
reepers13
Post Thu Aug 30, 2012 3:21 pm
yes mate
