coilover kits
e30-EVN
Post Sat Aug 18, 2012 11:59 pm
im currently looking into coilover kits for my car as the gmax gas shocks i have on the car at the mo are dead.!
i spent 250 quid on the shocks and spring kit 2 years ago and am looking to spend about that again (not gmax though!)
what have you guys got and and what do you have to say about the kit ect?
also i have seen the likes of JOM coilovers but they just look like front inserts with adjuster cups and independant springs on the rear with adjusters and seperate shocks.... while the dearer (800 quid jobbies) seem to be a whole assembly if that makes sense???
thanks for any info in advance 8)
e30-EVN
Post Sun Aug 19, 2012 3:27 pm
29 people all have nothing to say?? :?
anyone have any advise pls? :)
leeparkes
Post Sun Aug 19, 2012 3:42 pm
If you have proper coilovers on the rear iirc you will have to reinforce the top mounts or brace it to stop it flexing.
e30-EVN
Post Sun Aug 19, 2012 4:14 pm
Ah I've also heard of this before... Can buy the plates for this somewhere, can flippin remember where though lol.
Been thinking about the Jom coilover kit on eBay. Purely down to the current shocks being buggred until I can afford gaz or the like
ross_jsy
Post Sun Aug 19, 2012 5:01 pm
Tbh you are better off spending a bit extra on some B6/8's and a decent spring set rather than a cheap coilover kit
BATTS91
Post Sun Aug 19, 2012 7:22 pm
My cheap coilovers arent too bad tbh handles good with 9j wheels but i would upgrade to gaz if they were in budget as im sure all would
Duke137
Post Sun Aug 19, 2012 7:54 pm
Buy cheap buy twice Ant :)
Up your budget mate, beg steal and borrow and get GAZ or something similar I would say 8)
e30-EVN
Post Sun Aug 19, 2012 10:08 pm
i cannot do that ferg, i would love to but am having gearbox troubles yet again.!!
dam m42 boxes are crap, either its bad luck or a combo of the m52 and my right foot killing them off. either way i am now swapping to e36 328 gearbox and prop combo but with that comes an e30 m3 dif so cost and cant do it all at once :(
on the plus side im taking the plunge for e46 rack conversion and some sport seats finally as im fed up with sliding out of my seat in enthusiastic moments haha. bloody comfort seats 8O
anyway back on topic, one day i will splash out but for now i need to renew the knackered shocks so im going to prob go for the JOM kit for now.
wondered if anyone had fitted them and what they thought
e30-EVN
Post Sun Aug 19, 2012 10:10 pm
what set do you have mate?? i know the feeling, ive been looking at KW coilovers and also gaz but i cant stretch that far with the other things i have going on :(
BATTS91
Post Mon Aug 20, 2012 12:28 am
I got pro sport ones but exaxtly the same as jom i think . I had to cut the standard bottom spring perch off as it gets in the way of the coilover slip on thread , its all simple to do and self explanitory when you recieve the kit
Oh and ive never used te ajustable perches for rear tho but depends how low you desire
Found a pic .
No welding needed either :-)
mucka88
Post Mon Aug 20, 2012 3:16 pm
I brought set of JOM... but was fitting to my 1.6 and found out the hubs you need was different to mine as inserts. In the end had to sell my parts for funds as was out of work, but now looking for another set.
Duke137
Post Mon Aug 20, 2012 3:26 pm
e30-dk wrote:i cannot do that ferg, i would love to but am having gearbox troubles yet again.!!
Not having any luck with them gear boxes mate!
I reckon you are a crazy mofo behind the wheel :P
Jimbob
Post Mon Aug 20, 2012 3:43 pm
How much are M3 diffs? Only reason I ask is that you can buy the 2.93 (any ratio for that matter) CWP from American Ebay for about £120 delivered, you can then just have this fitted to your current diff.
This could save you some dollar which you could then be able to put towards your suspension.
bimanut
Post Mon Aug 20, 2012 5:19 pm
Jimbob wrote:How much are M3 diffs? Only reason I ask is that you can buy the 2.93 (any ratio for that matter) CWP from American Ebay for about £120 delivered, you can then just have this fitted to your current diff.
Nice idea but have you seen how much £ to refurb a diff :eek:
mucka88
Post Mon Aug 20, 2012 5:36 pm
Think i read somewhere, that audi 80/coupe struts fit and about 70mm lower. will look for this, to make sure.
Jozi
Post Mon Aug 20, 2012 8:00 pm
Yeah think it's Audi shocks that fit but would only really be needed if you go really low!
I'd go with some decent shocks until you can afford a good coilover kit. I've got BC Racing coilovers bassed on feedback on them and had one spin in a iS with them fitted.
There's a rally (I think) crowd that sells parts to make up coilovers.
I'm not someone in the know but I remember reading a interesting few posts on here about rear coils (proper coil over shock) and there's no need to upgrade the rear mounts as your actually loading them less with proper coilovers.
Ant: it's z3 rear reinforcement plates your thinking of, think they are a bmw item but easy enough to diy I reckon
Jimbob
Post Mon Aug 20, 2012 8:30 pm
Gareth's prices are very reasonable, then you have a brand new diff :)
mucka88
Post Mon Aug 20, 2012 8:45 pm
Yeh im looking into audi shoks, but not found any yet
BATTS91
Post Mon Aug 20, 2012 9:00 pm
Now what would be ideal for a coilover kit is smaller shocks ,cut down the insert tube and somehow tap a thread back in so the locking screw/cap still sures the shock in the insert tube .
Weld on coil over threads and proper coil over top hats to use a spring similar to gaz
I know theres sites out there but i havent found anywhere for top hats
harry_p
Post Mon Aug 20, 2012 9:07 pm
£20 a side a set from rally design
http://www.rallydesign.co.uk/product_in ... ro2d5rnk05
use the dampers of your choice.
never heard of anyone having to cut down the top of the strut and use dampers with a shorter body. i think you'll get the tyre hitting the front inner arch before you run out of travel due to the height of the strut body.
cheers,
harry
BATTS91
Im doing research on my idea as it goes question anyone 51mm struts is that inside or outside diameter ??
Demlotcrew
Post Mon Aug 20, 2012 9:17 pm
harry_p wrote:£20 a side a set from rally design
The problem with lowering/converting with a stock strut is that you end up with 20mm travel before you're on the bump stops. Unfortunately these weld on kits offer nothing. I for one would not be looking at making a kit with one of these collars as time and time again it has been proven they simply cannot offer the necessary OA suspension travel needed to be safe on the road and track.
Its a shame HSD don't do a kit for the E30, they produce a great kit for the money, my E36 M3 kit arrived this morning, looking forward to fitting it at the weekend.
harry_p
Post Mon Aug 20, 2012 9:20 pm
i put a set on mine yesterday :D
i love the idea of the preload being totally separate to the rideheight.
cheers,
harry
Demlotcrew
Post Mon Aug 20, 2012 9:21 pm
And how does it drive? Ive never driven an HSD equipped car, but I have not heard anything too bad about them, a few niggles with the finish, but for the money its hard to complain!
BATTS91
Post Mon Aug 20, 2012 9:25 pm
Them hsd look good but for the same price you could get gaz for e30 tho :/
Demlotcrew
Post Mon Aug 20, 2012 9:27 pm
HSD are in a different league to Gaz, you cant even compare!
harry_p
Post Mon Aug 20, 2012 9:29 pm
really well. im on full soft just to run them in, but start tweeking soon. over small ripples typical of an east anglian b-road they cope superbly, over cobbled they rattle the car less than the standard setup. theyre obviously a fair bit firmer, but nicely controlled.
i was conservative when fitting as i didnt want it absolutely decked. rear cups wound right up so you can't see any thread on the base, and the fronts with 35mm of the damper body inside the bottom mount has given a virtually standard ride height.
might be usefull as a guide for initial setting to base your desired ride height on.
cheers,
harry
harry_p
Post Mon Aug 20, 2012 9:31 pm
i'm affraid i've never been a fan of gaz, despite them being widely loved on here.
plus how much will a set of decent topmounts cost on top?
cheers,
harry
Demlotcrew
Post Mon Aug 20, 2012 9:32 pm
harry_p wrote:might be usefull as a guide for initial setting to base your desired ride height on.
Absolutely, having never really setup an E36 its going to take a bit of time and feedback from others, did you use the stock front ARB drop links? And what about wheel clearance up front, any spacers needed?
harry_p
Post Mon Aug 20, 2012 9:42 pm
standard m3 droplinks, i did wonder if i would need to shorten them, but they seem fine. i used 15mm spacers on 7.5in et41 sunflowers. could probably have got away with a little thinner, but there's still tons of room in the arches.
one point to note, if you're using evo strut top strengthening plates, they limit the amount of castor, so you can't push the topmounts far enough forwards to alter the camber with everything in place, so again you have to guestimate, then put the bolts through the tower and set the castor.
again, things i wish i knew before i had started, but in all the reading i've done hadnt found any mention of.
cheers,
harry
Demlotcrew
Post Mon Aug 20, 2012 10:07 pm
Good stuff, I will make sure to take a few photos of the progress :cool:
ross_jsy
Post Mon Aug 20, 2012 11:14 pm
BATTS91 wrote:Them hsd look good but for the same price you could get gaz for e30 tho :/
You do realise that Gaz golds are mediocre at best right?
I have never been in a car with gaz's that I thought rode well, always crashy (althought not been in an e30 with them).
Ask yourself why do you want coilovers? A lot of people seem to think they are the be all and end all of suspension but it really depends on what you need.
Realistically, how often do you adjust your suspension? Unless you are going to see regular track use coilovers are a waste of time IMO. The likes of Billstein know a lot more about setting up a dampner than you do and having adjustability is normally a bad thing for most users.
Just because every dubc0ck slams their turd on £200 coilovers doesn't mean that every car should have a set.
Duke137
Post Mon Aug 20, 2012 11:41 pm
Andrew you pic whore 8)
davethegoat
Post Tue Aug 21, 2012 12:10 am
I've also got a set of HSD's waiting to go on my car. :D
Demlotcrew and harry_p, are you using the E36 top-mounts? How are you mounting them?
I sent an e'mail to one of the Polish fleabayers today asking whether they could knock up a set of E30 spec camber/caster adjustable top plates to bolt directly to the HSD bearing carriers.
I've started a new thread is in order to stop crapping up this one!
http://www.e30zone.net/modules.php?name ... 48#2467748
(Sorry to the OP! :o: :D )
Edited to say: Duckmann has a set of D2 coilovers which I believe are for sale. He's in Denmark. Might be worth a PM?
e30-EVN
Post Tue Aug 21, 2012 11:34 am
some say...... :chuckle:
have a bit of a heavy foot and big balls ferg but this shouldnt be happening :( .. e36 m3 box going in soon, lets see if that can hold out to the might..... im confident 8O lol
nice thought mate, but dif rebuild is not cheap either... e30 m3 dif can be had for between 300-400 quid. but i will get 300 sheets back from selling my current 3.64 lsd so the m3 item would effectivley cost me 100.
thats the ones Brend, i will ring sytner while sitting down to get a price lol
