Removing lower crank Pulley M44 Engine
Post Thu Aug 16, 2012 6:33 pm
Can Anyone help, how do i remove the lower pulley from the crank in the below picture????
also i cannot get the water pump out, does the timing case have to be off for it to come free ?
its an m44 from a z3 if that helps
Dan320is
Post Thu Aug 16, 2012 6:48 pm
Alex, if it's anything like getting the same pulley off an M42 it's going to be a barsteward! In the end I had two pry bars holding the pulley still and a friend on the end of a three-foot breaker bar with a scaffold pole!
Post Thu Aug 16, 2012 7:19 pm
Bugger, ideally i want to fit a new chain, is there any way in holding the flywheel still?
Dan320is
Post Thu Aug 16, 2012 8:53 pm
Alex wrote:Bugger, ideally i want to fit a new chain, is there any way in holding the flywheel still?
On the M40 there is a hole in the bell housing for a peg to insert into the flywheel, I'm not sure about the M44.
Post Thu Aug 16, 2012 8:55 pm
I'am thinking it may be best to change the chain and guides once its back into the car
Dan320is
Post Thu Aug 16, 2012 9:08 pm
Alex wrote:I'am thinking it may be best to change the chain and guides once its back into the car
I've only ever done it with the engine in situ, just with bonnet/grills and rad' removed.
