cylinder id sensor plug
HairyScreech
That's the extra plug mounted under the diagnostic connector and next to the crank sensor plug right?
Correct, assuming we're talking about a M20.
HairyScreech
Yeah m20, I knew there was an extra plug there but totally forgot to check what it was.
Will look at routing the cam sensor signal down it for the m3.3.1 ecu.
Thanks Brian.
Thanks Brian.
