SPRAYING MY E30 JET BLACK, ANY ADVICE WELCOMED
stokiedundee
Post Fri Aug 10, 2012 1:26 am
Hi peeps, I'm wanting to spray my light blue e30 316i jet black but I need some diy tips so I can achieve a good result. But if anyone on here is good at spraying then I would be willing to pay £100 if they were able to do a good job. Please get intouch if you can help. Thanks for reading.
Ryan aka stokiedundee.
jaymos
Post Fri Aug 10, 2012 1:34 am
You wont get a good spray job for 100 quid.
bilal-ali
Post Fri Aug 10, 2012 2:32 am
Most body shops charge bout that much for a panel.
mucka88
Post Fri Aug 10, 2012 6:32 am
I agree, just had the part under winderscreen done as it was faded with small rust, that was £160, at a body shop
polsta
Post Sun Aug 12, 2012 10:47 am
stokiedundee wrote:But if anyone on here is good at spraying then I would be willing to pay £100 if they were able to do a good job. Please get intouch
words fail me
Nobby_N
Post Sun Aug 12, 2012 10:51 am
PMFSL is it matchbox car that needs painting?
kangman
Post Sun Aug 12, 2012 10:52 am
whats wrong with the original paint?? get a buffer and some compound
Sawyer_E30
Post Sun Aug 12, 2012 10:54 am
Bonnet respray and blend £600 last time I had any work done.
E30: The only E-number you should be concerned about
Sawyer_E30
Post Sun Aug 12, 2012 10:58 am
Is it going to be a drift car? :D
Post Sun Aug 12, 2012 11:07 am
The paint probably costs more than £100 dude
Barx325i
Post Sun Aug 12, 2012 11:25 am
I think the OP is offering to pay someone to come along and spray his car with the matt black rattle cans, which he may have ready for the job..?
@ OP, the first thing is to test that your paint doesn't react with the original, saying this, even if you do get a reaction, applying exceptionally thin coats - allowing them to dry and keep building them up that way is not only the way to get a better result, but will avoid any nasty reactions.
A decent finish is is mostly in the prep, masking, dust proofing etc.. As for prepping the surface, get some fine sand paper and key it up, wipe down with thinners and just spray.
HairyScreech
Post Sun Aug 12, 2012 5:48 pm
Sounds like a rattle can job boss.
Popcorn at the ready.
polsta
Post Sun Aug 12, 2012 9:03 pm
f**k it im in, il do it for £100 via 2 big tins and the throwing teqnique
sweep
Post Sun Aug 12, 2012 9:09 pm
A bodyshop wont spray a car for a long-un whats a matter with people ?
snakebrain
Post Sun Aug 12, 2012 9:40 pm
You'd spend £100 on sandpaper, panel wipe, masking and all the rest of it before you got near the paint...
Post Sun Aug 12, 2012 9:42 pm
Mine is costing me more than that in paint alone!
Barx325i
Post Sun Aug 12, 2012 9:45 pm
snakebrain wrote:You'd spend £100 on sandpaper, panel wipe, masking and all the rest of it before you got near the paint...
poundland mate, 5 rolls of masking tape & 2 packs of sand paper & solvent, stop off for rattle cans at halfords on the way home and job's a goodun for £60.. £100 on skillz and bob's yr bud
snakebrain
Post Sun Aug 12, 2012 10:33 pm
Do poundland sell filler? :D
sweep
Post Sun Aug 12, 2012 10:35 pm
Bodyshops and muckaics are robbers undreds o quids for easy work
verde
Post Sun Aug 12, 2012 10:54 pm
Id happily do it. Im a demon with a rattle can. Cant do grafatti, cant even spell it. But car panels and bikes, fuck yes. Pity im not local
Raise hell praise Dale.
Barx325i
Post Sun Aug 12, 2012 10:57 pm
if he drove up would yo do it for a bottle of buckfast? :D
verde
Post Sun Aug 12, 2012 11:01 pm
Im from edinburgh mate....bag of ching and its a deal
suchy
True Zone Relic
Post Mon Aug 13, 2012 9:55 am
Is this for real? You'd spend more that £100 on rattle cans, let alone proper paint. And then you have all the other stuff needed as mentioned above!
Sawyer_E30
Post Mon Aug 13, 2012 10:25 am
verde wrote:Im from edinburgh mate....bag of ching and its a deal
What's ching? :?
kangman
Post Mon Aug 13, 2012 10:28 am
What's ching? :?
thats what the iron bru boys call the white stuff..
And i dont mean milk :wink:
verde
Post Mon Aug 13, 2012 10:32 am
Haha correcto. But na as mentioned youl spend around 100 bucks on cans and sandpaper alone
Sawyer_E30
Post Mon Aug 13, 2012 11:35 am
Gotcha. :wink:
grantfk10
Post Wed Aug 29, 2012 10:38 am
Poundland do Gloss black rattlecans too winkeye
Post Wed Aug 29, 2012 11:43 am
sweep wrote:Bodyshops and muckaics are robbers undreds o quids for easy work
I wouldn't say it's by any means easy to do a professional job - it involves hours of rubbing down and masking for prep, careful matching/blending of paint then lots of polishing afterwards, and that's before you consider the fitting-up process of trim, lights, etc, etc.
Usually has to be done in dusty conditions, and under sometimes intense deadline pressure too.
euan
Post Sat Sep 08, 2012 6:50 pm
What's ching? :?[/quote]
And i dont mean milk :wink:[/quote
pmsl lol :)
magiccars
Post Fri Sep 14, 2012 7:40 pm
100 pounds sterling? :D You're optimist...
I actuall have a shop, could do the job for you. Will be more like a £1000 though. You have to bear in mind it's a lot of working going into it.
Firstly if you are doing respray you might as well do all the rusty spots, there is no doubts you will have them. That would mean cleaning (sand blasting) to a bare metal, then putting a coat on bare metal, sanding down, primer, sanding down, base, lacquer. Same will all other areas, they have be matted dow, all the small scratches and dints repaired (lets face it, you will have them). Once its primed, matted down and masked you can put a base and a lacquer. Materials alone will cost more than a £100!
Let me know if anyone will do it for tha.
