Using an Automatic M52 Donor
Motorhole
Post Thu Aug 09, 2012 12:24 pm
There are a lot more cheap 328i autos around than manual cars so may consider an auto donor and get the 'box seperately. I read earlier that someone had already posted some questions regarding the wiring loom having a few extra bits and bobs - if that's no problem, then that's fine.
Also, would I need a prop from a manual car? Are there any other bits I would need, aside from E30 325i clutch, flywheel & starter?
Cheers!
Post Thu Aug 09, 2012 12:36 pm
Nowt wrong with using an auto donor car.
The auto loom is separate to the engine loom, although they run alongside each other. But no major mission to separate.
As for prop, it very much depends on what manual box you are going to use.
Using an E30 gearbox removes hassles of getting an appropriate diff ratio sorted out.
Motorhole
Post Thu Aug 09, 2012 12:50 pm
Will be using the E36 gearbox as I have already sourced a Z3M LSD in 3.15 flavour, which of course should mate up to the E36 compact rear end I have without trying to find another pair of output flanges.
Post Thu Aug 09, 2012 1:43 pm
328i box and prop then, the linkages also work IIRC or you might need 325i/M50/Getrag linkages
Jozi
Post Thu Aug 09, 2012 3:15 pm
Redcar on here just did his auto-loom, have a chat with him and check his thread he posted not long ago with a few questions.
redcar
Post Thu Aug 09, 2012 3:32 pm
Thanks Jozi. I did my loom but I haven't tested to see if it works yet so can't really advise anything as of yet! winkeye
Motorhole
Post Thu Aug 09, 2012 3:58 pm
Thanks for all the help folks! All information worth taking on board.
randomspeedfreak
Post Thu Aug 09, 2012 4:40 pm
mine came from an auto loom, no hassle at all to remove it - find all the leads that go to the transmission ecu (the small one) and snip them following them all the way back
