Price to send a wheel with tyre?
sweep
As above and who do you use?
Barx325i
someone sent me this via email only the other day:
http://www.carpartcouriers.co.uk/acatal ... Tyres.html
Dan320is
Here you go. http://www.paisleyfreight.com/alloy-wheel-courier.php
Used them many times without any hassle.
sweep
thanks
bmw9818
just use interparcel, and myhermes at £6 i sent a 15" bbs,
Barx325i
Sorry, but you're talking rubbish, unless you sent it next door and it was made from polystyrene
Their minumum, standard service without a signiture
Myhermes Between 5-10 Kg - £ 7.14 a wheel alone is between 5 & 10kg
Myhermes Between 10-15 Kg - £ 8.39 - if you wrapped a light bbs featuring a 205.50 it'd be over 16kg
Interparcel a quote on 16kg - £8.49 + VAT
Nither of which are remotely close to £6
bmw9818
go on interparcel, average dimension 8kg 50 x 50 x 30cm £4.99 +vat myhermes =£6
Barx325i
back to the tire question then
bmw9818
it was with a 205 tyre, ive used them a few times for loads of items, they dont check it to the gram and mm, as long as its a reasonable measurement ive never had an issue,
Barx325i
It's not exactly mm even a 205.50 is 59cm & presume you wrap it?
It's not exactly gram either - my RS's with light 195.45's fitted were a hell of a lot more than 8kg, std bbs & 205.50/55's are 14kg min nearer 16+
There you go Sweep.. buck the system & you'll be reet..
Get charged for it being massively over the size & weight & Mr 9818 will pick up the charge
I prefer to use UPS via interparcel. Very reliable.
bmw9818
ive never had an issue tbh, i just wrap it in some bubble wrap and bin liner, sent the wheel and it arrived as did a load of other items,
doubt theres gonna be a bloke there with a ruler and a scale measuring every item so as long as its reasonable, dont worry about it
Barx325i
fair point there, but if everyone did that, their trucks would be overweight & bulging at the seams..
