Post
Tue Jul 31, 2012 6:49 pm
It's not the failure of the NiCd batteries as such that causes problems, but the fact that these type of batteries tend to go short circuit when they fail. This presents a heavy load on the power feed to the tacho. and temp. gauge, dragging down the voltage, and making them fail.
No problem in getting suitable, if not absolutely direct replacement, batteries either. CPC and RS Components have plenty.
Even if fitting a complete replacement cluster, it's still advisable to identify which type of batteries it has, and to replace them as a matter of course if they are the NiCd type. At the same time, check the small filament bulbs on the LED display panel, the soldering of the joints of the large 220 ohm resistor, the soldering on the speedo. contact pins and the tightness of the two small brass nuts on the back of the case.
If the SI board has lithium batteries, the unlikely failure of these causes no other problems other than the loss of SI board memory if the car battery is disconnected.
