Its a zf part number, You have to contact them direct. I used this to choose my one
http://akpp-city.ru/pdf/5HP24.pdf
This is the part number I used.
Just make sure the one you choose has the location hole for the flywheel sensor.
M60 Conversion
turk
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
Phill172
Not that i want to share this, as I want it but cant afford it!
http://www.driftworks.com/forum/parts-s ... ost2148230
no idea what fly/clutch he uses
turk
thats a noce plate. do you have to use the m60 starter or match the m52 starter to the flywheel?
Sump Baffles
TrackDays
Sump Baffles
TrackDays
turk
It must need a custom flywheel as well then im guessing?
Sump Baffles
TrackDays
Sump Baffles
TrackDays
Phill172
Been trying to find out what set up he uses
BATTS91
Am i right in thinking that adaptor is only good for lhd , if rhd was to use it would tere be ery limited space because of starter and steering linkage on ther same side ??
