rear brake pipes holy f***
e30mtech
Post Sun Jul 29, 2012 9:24 pm
well i been building my e30 for a year and finally put it in for an mot on friday,
all it failed on was 3 brake pipes small patch to weld in passenger footwell and a fuel leak, was well happy with outcome.
garage quoted £160 for pipes and welding. i have done everything on this car myself engine conversion etc etc so dont want to put it in the garage.
i cut out the rot and will weld it myself, also done the fuel leak.
i went to do the rear brake pipes and jesus, that is the worst setup i have seen with the location of the pipes from the splitter to the flexis, i done the 2 pipes running from flexi - cylinder but dont think i can do the other ones without a ramp tbh as they a nightmare.
anyone done this themself, any pointers, they look original and never done so the unions are beggered.
Post Sun Jul 29, 2012 10:10 pm
Done plenty of them myself - always when the fuel tank, and often when the rear beam, is off of the car.
Don't attempt to undo anything in situ. Just chop through the steel pipes and the flexis, then destroy the U shaped clips holding the ends of the flexis to the body by twisting them with side cutters. With all three pipes to the tee piece cut, rotate the whole thing anticlockwise with grips while attempting to unscrew the fixing bolt.
When you have the tee piece off, clamp the nuts, one at a time, in a vice, and rotate the tee piece to unscrew the nuts.
£15 of copper alloy pipe (enough for the whole car), new 10mm short pipe ends at 10p each, hoses from carparts4less, and the U shaped clips from BMW and the jobs done for the next fifteen years.
sweep
Post Sun Jul 29, 2012 10:23 pm
Do you use this carparts4less yourself brian ?
e30mtech
Post Sun Jul 29, 2012 10:27 pm
i have all the parts just didn't want the hassle of removing axle etc, how much of a pain is that to do is it worth it to save £120?
Post Sun Jul 29, 2012 10:49 pm
sweep wrote:Do you use this carparts4less yourself brian ?
Regularly. It's an offshoot of Eurocarparts, using the same part numbers, but without the silly fake sales.Last order even had ECP packaging.
May be a coincidence, but up to now, everything I've ordered has been correct first time.
Post Sun Jul 29, 2012 10:51 pm
e30mtech wrote:i have all the parts just didn't want the hassle of removing axle etc, how much of a pain is that to do is it worth it to save £120?
You don't need to remove the axle; it's the fuel tank that gets in the way, and yours could possibly do with a refurb anyway?
harry_p
Post Sun Jul 29, 2012 11:02 pm
I did it without removing the tank or subframe.
Bit of a fiddle but not impossible. As said, don't even bother trying to undo the old joints, snip them off and use as guides for bending replacement pipes.
There should be just enough room to get to the joints behind the subframe and nip them up, but not enough room to undo old crusty ones.
cheers,
harry
verde
Post Sun Jul 29, 2012 11:05 pm
My old man did it without removing anything aswell, it was a bit of a bar steward but we managed
Raise hell praise Dale.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Jul 30, 2012 6:33 am
I had the beam off when I did mine, but as others have said it is possible to do it with the beam in situ. Here's a pic so you can see what you're up against:
(and yes, I did clean up the surrounding rust).
Brian's advice is the perfect solution. You may also find you have to replace a section of the feed line as well, so I placed the joint by the fuel filter under the sill.
e30den
Post Mon Jul 30, 2012 8:12 am
Why not re-route the pipes full stop ?
scallyally
Post Mon Jul 30, 2012 8:28 am
Carparts4less is the mail order division of eurocarparts (same vat). My local eurocarparts matched their online prices when asked ( nicely) and I saved over £20 on £65 of service parts. Well satisfied!!
