I have a late 1989 2.3 E30 M3 UK Spec. The clutch pedal occasionally sticks, by that I mean when the pedal is depressed some time it stays depressed and you have to pull the pedal back up yourself.
Any ideas whys this is happening? Is it the mechanism sticking? It is a bit interesting at traffic lights especially when the clutch sticks and your sat there revving the engine!!
Any help would be greatly appreciated
E30 M3 sticky clutch pedal
busterm3e30
E30_Maniac
Its the clutch slave cylinder.. Cheap fix.. Mine was doing exactly the same thing.. I just had my m3 Fixed on Friday..
busterm3e30
cheers where did you source the parts from?
busterm3e30
busterm3e30
thanks where did you source the parts from? Is it a standard E30 part?E30_Maniac wrote:Its the clutch slave cylinder.. Cheap fix.. Mine was doing exactly the same thing.. I just had my m3 Fixed on Friday..
kundiboy
Yes the slave and master cylinders are the same as all of the E30 range.
1988 Diamond Schwartz E30 M3
