E36 318ti to E30
Sawyer_E30
Post Sun Jul 29, 2012 10:12 am
Hi all,
It's been a while since I was last on here and ages ago since I last owned an E30.
I have recently moved home and my neighbour has got himself an E30 WIP, which made me miss how they look and handle.
I currently have an E36 318ti (1.8 - M42), pics below, which is on coilovers and polybushed front and back. Works well and does the job round the bends, but still doesn't look right to me. It looks like sombody tried to make a coupe but only had the parts for the sedan and then reversed it into a wall. :)
My question is:
Could I transfer the parts on my compact onto an E30?
The main bits I want obviously is the suspension, but I'd also like to throw on the steering rack, brakes, 5x120 hubs etc.
I know people use the compact trailing arms but could I throw on the whole rear beam, along with the diff?
Also given that the compact has covered just 84,000 why not the engine too?
Would love some input especially if somebody has done something similar. :D
Much appreciated
E30: The only E-number you should be concerned about
Post Sun Jul 29, 2012 10:27 am
AFAIK, the E36 Compact used the E30's rear beam, so that should fit...
Sawyer_E30
Post Sun Jul 29, 2012 10:30 am
Good good, hopefully means I can disconnect the prop and the beam and the rear should come away from the body as one. :)
Post Sun Jul 29, 2012 10:35 am
I think you need to change the spring/damper rates though.
No reason why the M42 shouldn't fit, either.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jul 29, 2012 10:39 am
In terms of drivetrain, there's very little that's directly swappable; everything will need fettling to some degree. For example, while the rear beam is the same, the rear diff carrier is not, so you'll have to swap diff covers to an E30 style. And while the trailing arms are the same, you're now commiting yourself to a 5-lug setup which requires extensive mods at the front end (i.e. E36 M3 parts at the very least). You won't be able to use any of your front-end components on an E30, although the steering rack is swappable with the appropriate kit.
The gearbox will have different ratios to an E30 M42 box so you need to make sure you pair your diff to your box; no mixing and matching.
And as for the engine, you'll need so many ancillary components to fit an E36 lump into an E30 (manifold and sump for starters) that it would be cheaper just to buy an E30 engine to start with.
In short, don't go tearing apart a decent E36 compact when a decent E30 318iS can be had for less time and money.
Sawyer_E30
Post Sun Jul 29, 2012 11:03 am
Thanks for the above info, loads for me to digest. I'd love an iS but they seemed to have disappeared. Still loads of 316i's though.
harry_p
Post Sun Jul 29, 2012 11:43 am
Not all strictly true, sure you would need m3 evo spindles and arms, but his existing coilovers will be fine using e30 top mounts.
Spring rates will be very similar as the suspension layouts are the same and the cars weigh very similar amounts. Close enough for normal road use anyway.
Pretty sure the rear diff will bolt straight into an e30 too, as I seem to remember the compact using a single rear diff mount as per e30, while the rest of the e36 range had twin rear mounts.
Not sure what prop you would have to use as I don't know whether the diff to gearbox distance would be the same with the bits bolted into an e30 shell.
But I agree it would be a shame to pull a decent compact to bits as they're worth money as they are, might be better finding a rotten but mechanically good one as a donor?
Or, better still, just start with an e30 318is in the first place and add an e46 rack to make it feel more lively.
cheers,
harry
leeparkes
Post Sun Jul 29, 2012 12:03 pm
Diff and backplate will be the same as E30 so the whole rear end will bolt up.
Sawyer_E30
Post Sun Jul 29, 2012 12:05 pm
I did think the compact rear had been nicked from an e30. Why wouldn't the front compact hubs fit an e30 effectively making it a 5 stud.
leeparkes
Post Sun Jul 29, 2012 12:08 pm
Why not just build an E30 to your own spec? if all you want is IS power it should be quite easy.
harry_p
Post Sun Jul 29, 2012 12:23 pm
Sawyer_E30 wrote:I did think the compact rear had been nicked from an e30. Why wouldn't the front compact hubs fit an e30 effectively making it a 5 stud.
Because the mounting points on the sell are in a different place.
It will all bolt up, but the wheel will sit too far back in the arch and will handle horribly.
So, you need to use e36 m3 evo front arms which are longer, pushing the wheel further forwards, and use offset front arm bushes to add to the effect.
You can't bolt an e36 hub to an e30 spindle as the diameters are different and the e30 bearing is thinner and doesn't leave enough thread for the hub but with an e36 bearing.
cheers,
harry
Sawyer_E30
Post Sun Jul 29, 2012 12:27 pm
Got it. Thanks Harry
leeparkes
Post Sun Jul 29, 2012 12:38 pm
You could make that compact look nicer with Mtech bumpers, different wheels etc...
Sawyer_E30
Post Sun Jul 29, 2012 12:41 pm
Nice! I do like what a lot of the Americans do by supercharging them. :P
leeparkes
Post Sun Jul 29, 2012 12:46 pm
I M52'd mine a few years ago, still got it and going strong.
Here's the build thread...
http://www.e30zone.net/modules.php?name ... 53&start=0
Looks like imageshack deleted a few pics though. :(
Motorhole
Post Sun Jul 29, 2012 3:15 pm
This S14-engined compact rally car looks the dogs with the motorsport wheels and wide arches.
http://www.rallycarsforsale.net/clas/in ... s&id=63069
