viscous.
tcos
got a m10 auto, takes quite some time, but starts to heat up, motorway today @ 70mph creeping up towards the red, could this be the viscous, as when nice and hot can stop it dead with a rolled up snooze paper!!!!!!!!!!!!!!!!!! not the car! the viscous
zaust
- Zone day release
tcos
so its not a old wifes tale!! is this the way to test the viscous? another thought, would the wind coming through the front of the car @ 70mph not cool the rad down??????
jmc330i
Sounds like the viscous clutch is in need of replacement. Having said that, the fan won't be doing much at 70mph, the airflow through the rad should keep it cool enough at that speed, so I'd be giving the whole cooling system a once over. Has the rad been renewed at all to your knowledge? Rads are actually service items that a lot of people never replace.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
tcos
umm, not sure, but thats what i thought @ 70mph the flow of air should cool it back down, but as nice as it was!!! heaters on full pelt just kept it below the dred red.
e30den
I would be thinking water pump and change the thermstat whilst your at it.
tcos
just one more thing, top hose hot, bottom hose hot, so am i right to say the rad is doing what its meant to be doing????
jmc330i
It should keep it cool whilst on the move. Today, my M40 got up to 3/4 whilst moving in slow traffic, but once up to 30mph, it dropped below 1/2.
I've driven about 20 miles of motorway in a 325i without a fan fitted and that sat below 1/2 until we came off the slip road and came to a stop.
James
'91 325i Sport
'91 325i Sport
harry_p
the car moving along at 70mph will push far more air through the radiator than the fan ever could!
i'd be looking elsewhere, but it sounds like the viscous could be knackered aswell.
both radiator hoses hot just means there is water going through the radiator, it could still be partially blocked and is no longer cooling effectively.
cheers,
harry
harry
Exactly! Viscous coupling, and the fan attached to it, are only impeding the airflow slightly at 70 MPH, not aiding it.harry_p wrote:the car moving along at 70mph will push far more air through the radiator than the fan ever could!
Radiators scale up, and don't last for ever.
Captain_Birdseye
Maybe air in the system...?
To find out the way I did is probably not the best way, loosening the coolant sender cap by accident when hot and get rid of the air by blowing coolant sky high in a 5 meter radius.
There's a plethora of possibilities in my recent and obviously very limited experience.
Last edited by Captain_Birdseye on Fri Jul 27, 2012 9:53 pm, edited 1 time in total.
Barx325i
was thinking air lock..
