m50 convertion
chaz_316
Post Mon Jul 23, 2012 11:40 pm
im thinking about swapping out my old 1.6 lump for an m50 either a 2.5 or a 2,8, after reading the wiki i know i need an e34 sump and ill proberly leave it married to a e36 gearbox but what mounts will i neeed to sit it all in there? (does it depoend on what e36 box?)and what gearbox cross member can i use?
next issue is a prop, as far as i understood the wiki i can cut and shunt a prop together from the e30 and e36 props, do i need a a e30 325 prop or will my 316 one do?
being a 316 ill do a disc convertion on the rear, as for the fronts are standard 325 brakes enough? with braided lines? or is there another alternative? going to get GAZ coilovers for it with correct weight springs.
it will all be insured properly before someone says lol
ant tips would be great :)
Post Mon Jul 23, 2012 11:53 pm
if your using an e36 box you will need a long ratio medium case dif like a 3.15 or less
you need e36 engine arms and e28 m535i engine mounts [ecp]
you can use an m40 box with 320i prop and gear linkage or a 318is box with 325i prop with any e30 diff you like
chaz_316
Post Tue Jul 24, 2012 12:01 am
oooo will the m40 box work??? mint :)
what diff would work best with that??? im not after mad accleration :)
Post Tue Jul 24, 2012 9:03 am
i have m40 box,320i prop and gear linkage with a 3.64 medium case lsd .
0-60 is 14.6 down york drag strip .
BATTS91
Post Wed Jul 25, 2012 4:01 pm
If i was you id stick with e36 box , go m52b28 , 2.8 box ,2.8 prop ,fook E28 mounts make some using box section and a hockey puck there much better in my opinion , diff well a 3.64 tops out at 130mph ish but gets there quick leaving e36/46 m3s behind ya or for abit of economy go for a lower ratio ;)
maf260
Post Wed Jul 25, 2012 4:07 pm
magpie wrote:0-60 is 14.6 down york drag strip .
Your car takes 14.6 seconds to get to 60? Does it only fire on 2 cylinders?! 8O 8O
BATTS91
Post Wed Jul 25, 2012 4:31 pm
Must be in reverse gear !
Post Wed Jul 25, 2012 6:03 pm
No it's true, he creeps over the line when the lights change, puts the blunt back in the ashtray and then sets off :)
Post Wed Jul 25, 2012 6:57 pm
pmsl @ Lee
should have said 1/4 mile DOH!
BATTS91
Post Wed Jul 25, 2012 9:54 pm
lol!!
Post Wed Jul 25, 2012 11:01 pm
:lol:
had my fair share of those over the years on here mate ^
BATTS91
Post Wed Jul 25, 2012 11:23 pm
Haha i can imagine , But havent we all tho lol .Part of the enitiation me thinks
