i did some motorway driving yesterday and noticed that at "cruising speed" the revs were pretty damn high in 5th gear which i found annoying...so i was wondering, is it possible to fit a 6-speed gearbox in my 320i touring and would it make enough difference to bother with? if so would i need a mechanic? or would my common sense be enough?
Thanks.
6-speed gearbox
cecotto479
- Caution Unreliable Seller
Far easier to fit a taller diff.
1981 E23 735i
jmc330i
As above, change the diff for a taller ratio and it will rev lower at speed, but at the expense of some acceleration. I think 320i tourings run a 4.27:1 diff, so a 3.91, 3.73 or 3.64 from a 325i will lower the revs. Not sure how well a 3.64 would work on a 320i though.
The E36 M3 6spd box should fit the M20, but the box will be rotated slightly, so a modded gearbox mount and gear change linkage will be needed as well as a custom prop. And after all that, you will still need to change the diff to a 3.64 or 3.73 as the 6th gear on the E36 M3 box is pretty close to 5th gear on the M20 box.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Grrrmachine
- E30 Zone Wiki / Team Member
As others have said; it's a tradeoff between cruising and acceleration.
What you need to bear in mind is that E30s already have an "overdrive" gearbox, meaning the final drive is less than 1.00. On your Touring, it should be 0.81 in fifth gear.
Considering most later BMWs have a final drive of 1.00, and you'll be getting a six-gear box from a later car, then having a sixth gear will still only give you a final cruising speed-and-rev of what you have now; it'll just narrow the gaps between the existing gears you have so that there's not such a massive jump between 2nd and 3rd.
A 4.10 diff will bolt up to your car without having to change any other components; it won't make a huge difference to your cruising revs. But going any lower will not only require some other changes (prop, I think), but it will also seriously blunt your around-town acceleration. And a 320i Touring is sluggish enough as it is.
Your serious options are either to do an engine swap to a 2.5 (M20 or M50), or buy earplugs.
cecotto479
In what way will a 325 engine swap improve matters?
Engine speed is a direct function of road speed and drive ratios.
If you use the same gearbox and diff, you can bolt on whatever engine you like, but it'll still be doing the same rpm as the current setup at the same road speed.
325i engine gearbox and diff would be the way to go.
1981 E23 735i
Grrrmachine
I mention the 325 only in the sense that better torque will allow a taller diff; I didn't mean just a new lump, but also all the drivetrain mods that go with it.
I suppose a cheapy cheap option would be to fit tyres with a bigger rolling radius too.
No change of prop. needed to bolt up any E30 diff. of any ratio. Prop changes are only needed when gearboxes are changed.
The only reason they fitted such a short ratio diff is because the 2.0 litre is so guttless it cant pull a normal diff ratio.cecotto479 wrote:In what way will a 325 engine swap improve matters?
Proper engine first, then proper ratios
Morat
Harsh, but fair....
hoohaa
it doesn't seem that gutless to me, but that could be my last cars were diesels or 1.1's...
it would be nice having a longer 1st gear tho if doing any of this diff stuff would help that.
i have no idea about any of this tho, i managed to tighten my alternator belt and was pretty chuffed with myself. so that shows how much of a rookie i am at this lol
My 1987 320iSE had a 3.64:1 diff, the same as a 1988 325iSE I had after it. It seemed OK, if a little leisurely on acceleration.
