I'm looking at changing my pierburg head of crap to a Weber DGV. After hours of research, I still can't find a straight answer. So, masters of the M10:
Do I need an adapter plate to put a Weber DGV on my M10 E30?
The internet seems to have loads of information for 2002's, and it says you either need the special solex manifold, or an adapter plate, but I'm assuming 2002's have a single barrel?
If I do, would this kit be the right way to go?
http://www.webcon.co.uk/shop/shopexd.asp?id=778
Any help or answers would be great.
Does a Weber DGV need an adapter plate?
Old post, but did you replace the Pierburg or gave up and replaced the engine?
I've put in a Weber 32/34 DMTL pre-jetted for the M10. It's a straight bolt on, and they also have a rubber mount for it.
Now wish I had put in the twin webers
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
- Brianmoooore
The 'correct' Weber kit for the E30 M10 bolts straight on to the existing manifold with a thick rubber gasket, but no adaptor plate. There is an adaptor plate fitted to the top of the Weber to adapt it to the existing air filter box.
Big bump :p
I persevered and went with the DGV. I have no experience with the DMTL that is the standard conversion so I can't compare.
It was all a waste of money in the end. All it did was make lots of noise, and it kind of went fast. The fuel economy wasn't too bad either ~ 30mpg
Any pics of the wheezy geezer?
Maneesh
