my M30 conversion I'm running a E28 535I rad and a large push fan...
if I put a thermastat in my car it runs too hot! and temp keeps on slowly rising!
any ideas? thanks.
m30b35 E30...
mcbonio
Sounds like the thermostat isn't opening when its at temperature. Do you know if the thermostat works correctly?
Alburglar
...put it in a glass jug and pour in boiling water from the kettle, to see if it opens.
M42 - rightness! with proper 4.27 LSD
Minstrel
the stat is new and opens fine but just runs too hot now
- E30 Zone Meets/Events Team
You need an 80 degrees stat for the m30.
Rav335uk wrote:You need an 80 degrees stat for the m30.
A few small holes drilled in the outer circumference of the thermostat is a worthwhile mod.
Running these engines without a thermostat WILL cause damage. The thermostat acts as a restriction in the coolant flow, with it removed the coolant finds the easiest , IE shortest, path around the engine and this results in the rear of the engine running a lot hotter than the front
staley_turbo
Well I didnt know that, Time to put mine back in.pacerpete wrote:Rav335uk wrote:You need an 80 degrees stat for the m30.
Andyboy
- Alpina Colada
Just one hole is needed. About 2mm diameter and at the top. It just helps bleeding air out.
A lot of owners of K Series donks do this - it prevents a thermal shock when the stat opens and dumps cold water into a hot head. Apparently.
