I need to get my track rod ends off to change the steering gaiters.
Can someone please post a link to a good ball joint separator, no gucci snap-on stuff but no cheese either!
Recommend me a ball joint separator
TheMoney
320i PBMW track car
cecotto479
- Caution Unreliable Seller
Two hammers has never failed for me.
1981 E23 735i
You don't need to remove the track rod ends from the steering arms to change the rack gaiters.
Just turn the track rods until they unscrew from the rod ends.
Tracking will need to be set afterwards, but count the turns, so that you get it approximately right when you put it back together.
mcbonio
My cab just failed its MOT on exactly this, I just used this from halfrauds. Easy to use.
http://www.halfords.com/webapp/wcs/stor ... yId_255216
Jos
this, if it's not coming loose you aren't hitting it hard enough.cecotto479 wrote:Two hammers has never failed for me.
'94 e36 tree climber
TheMoney
Thanks, bought it.mcbonio wrote:My cab just failed its MOT on exactly this, I just used this from halfrauds. Easy to use.
I am no good with hammers and brute force stuff I need tools!
Thanks everyone.
320i PBMW track car
Jos
don't attempt your rear subframe then
If you use copper slip around a clean ball joint before fitting you dont need to hammer the f**k out of it if you ever need to separate it.
I would use Brians explained method, but mark the track rod and end with a hacksaw so that it goes back on in exactly the same place.
Alburglar
Get the scissor type ball joint splitter, preferably with long arms, and you will never have to hit anything again. You will also never damage a ball joint baited ever again. This one is a tenner
http://www.ebay.co.uk/itm/120703206061?redirect=mobile
M42 - rightness! with proper 4.27 LSD
They are great if you dont mind repairing threads on ball joints..
But better than splitting gaitors with the hammer in fork type, or smashing the f00k out of the hub with a lump hammer
mcbonio
The cup type is best, pop it over, wind the nut down and pop.! Easy, and you don't damage the boot on the joint.
