diesil engine?????????
gman1
Just a thought............you see alot of engine swaps on here,but have not heard of a diesil!!!!!!,is this possible??
Grrrmachine
- E30 Zone Wiki / Team Member
jmc330i
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
harry_p
Why would you want to?
cheers,
harry
harry
Farmers innitharry_p wrote:Why would you want to?
shadrack
not bad idea get a nice 325tds to butcher and make an e30 a good mpg'd daily driver!!
nickso
- Location: Go do that voodoo that you do so welllllllll!!
Poor idea when you factor in the unreliability, conversion cost and cost of diesel over petrol. A mentalist would need to do a lot of miles to justify it.shadrack wrote:not bad idea get a nice 325tds to butcher and make an e30 a good mpg'd daily driver!!
'88 e30 328i M52 track bint.
Kos
just buy an e36 325tds if you want a nice diesel daily
an e36 is a far superior car than an e30, job jobbed
shadrack
doubt it, ive got a t reg 318is coupe and the e30, the e30 rules anyday!!!Kos wrote:just buy an e36 325tds if you want a nice diesel daily
Unless you have a steady supply of red or Vcheap/free diesel I wouldnt even consider it.
Oil burners FTL
Oil burners FTL
bmw9818
sunflower oil?
harry_p
Old diesel engines are rattley, slow, heavy and not particularly economical.
New diesel engines are a bit lighter a bit less rattly, have tons or torque but are expensive and complex.
You'd have to do a massive amount of miles to cover the conversion cost against driving a 318i sensibly.
If you want a cheap diesel smoker, buy a cheap diesel smoker and leave the e30 as it was.
cheers,
harry
harry
leeparkes
If fuel economy is your thing run a petrol engine on gas.
So your car will smell like a chip shop for about 10p per litre cheaper?bmw9818 wrote:sunflower oil?
I fill my E34 up with LPG for 58p per litre at the moment, and dont mind dropping under 20mpg for town driving at all
Kos
An e30 has character and charm that an e36 lacks, but the e36 is a superior car.shadrack wrote:doubt it, ive got a t reg 318is coupe and the e30, the e30 rules anyday!!!Kos wrote:just buy an e36 325tds if you want a nice diesel daily
Child like comments like "the e30 rules" is biased personal opinion, not fact
My e39 is far superior to the e34 or e28 equivelant. If it wasn't then bmw are doing something wrong
TouringTash
Surely the added vibrations from an oil burner would play havoc with the grapes of wrath?DanThe wrote:Farmers innitharry_p wrote:Why would you want to?
318i Touring
corrected for ya KosKos wrote: My e39 is far superior to the e34 or e28 equivelant until it breaks down
polred
I have an e36 coupe with a 2.5tds engine in it,it managed a 15 sec 1/4 mile at 92.4mph last mth.I was hanging with some big boys,ie a twin turbo sierra(225hp),328 sport,saab aero hot(260hp),my problem was BALD tyres lmao! Of the line 1st gear was useless,2nd i was spinning a bit then once i hooked up,the cars i was running against werent pulling away! Beat a Toyota Alteza(212hp) and a tuned seat tdi.
Back to drag on the 21st,with 18s on with decent rubber. Very confident in my re-match with these cars i lost to. Standard engine is slow,but with a few tweaks goes really well. FMIC,chip,EGR delete,cone filter,de-cat,apexi B/C set at 1.5 bar.
This car replaced an 02 e39 M5 i had,and its been its perfect replacement.30+MPG boosting everywhere,devils fuel FTW! Paul...
aze30
i know diesels make huge amounts of torque compared to their petrol equivelents....for example a engine from a 330d would make more torque than that of a 328i m52polred wrote:I have an e36 coupe with a 2.5tds engine in it,it managed a 15 sec 1/4 mile at 92.4mph last mth.I was hanging with some big boys,ie a twin turbo sierra(225hp),328 sport,saab aero hot(260hp),my problem was BALD tyres lmao! Of the line 1st gear was useless,2nd i was spinning a bit then once i hooked up,the cars i was running against werent pulling away! Beat a Toyota Alteza(212hp) and a tuned seat tdi.
remap both of these and which would be more powerful?
we all know where this leads but i think id favour a remapped diesel lump in some cases if the prices for the conversions were similar
EFAe30topless wrote:corrected for ya KosKos wrote: My e39 is far superior at breaking down, emptying my wallet and making me look more council in general compared to the e34 or e28 equivelant
shadrack
i have both and have had 3 e30s and 4 e36s, e36 are very porely built by comparason to an e30, and generally worse to drive, i think e46s are better but the e36 is a shedKos wrote:An e30 has character and charm that an e36 lacks, but the e36 is a superior car.shadrack wrote:doubt it, ive got a t reg 318is coupe and the e30, the e30 rules anyday!!!Kos wrote:just buy an e36 325tds if you want a nice diesel daily
Kos
Any car that's not looked after is shed
With your words of wisdom on X5 gearboxes its advisable to not take any of your comments seriously like buying a TDS and fitting it into an e30
An e36 is more comfortable, usually better optioned, quieter, they rot less and far more economical and safer than any e30. They also handle better out the box
A 10 year old mondeo is better car than an e30
shadrack
dont bother then ruin an x5, funny tho as ive an 06 x5 as well and had a 01 one before that!!! x5 gearboxes do not need oil changes ever, they dont have any pattern to fail all i know is ones that have been opened fail more than ones that havent, all my cars are maintained perfectly by me! if you love a 10 year old mondeo why not just buy one as there about £300
Kos
Who said I love 10 year old mondeos ? I just stated fact
As for x5 gear boxes, an oil change does not involve opening the box. You dont even have to change the oil every year but there is no harm in changing the oil which is 7/8 years oil, been through 10's of thousands of heat cycles and would benefit from refreshing
If there is no pattern to them failing how do you know that ones that have been 'opened' have failed ?
On a used car, you do not know how it's been treated / driven / maintained
If you love your e30 some much and think its a better car then an e36 why do you drive a wanker chariot like an X5 ??
Go away and build your e30 325tds as you think it's going to be the best thing in the world
E30's are fun to drive & own. anyone who's onthis forum has an interest in them, a lot of us do love them but enthusists will agree that a lot of them are scrap and there are better cars out there like e36's
Simply having an economical car is not the motivation for owning an e30
Your idea was daft to say the least and your comments / ideas are daft
mattrs
Plenty of places sell cherry (about 90pence per litre) and the chances of getting dipped in a car are pretty low, let alone a petrol car!
I bet an e30 with a m57 lump (out of the 530d) would pull like a train and return 35-50 mpg!
shadrack
might just do that this forum is just full of people slagging off other peoples cars and any question they have are just met with prick comments like yours i was mearly saying a diesel conversion would be a good economical car, i couldnt give a flying f**k about economy thats why i have an x5 and as for it been a ****** chariot wats that suposed to mean??? is it cos its not to your tastesKos wrote:Who said I love 10 year old mondeos ? I just stated fact
If you love your e30 some much and think its a better car then an e36 why do you drive a ****** chariot like an X5 ??
shadrack
exactly, think that 'kos' has the dummy out, and i never started this thread it was just i thaught a good experimental idea..mattrs wrote:Plenty of places sell cherry (about 90pence per litre) and the chances of getting dipped in a car are pretty low, let alone a petrol car!
The 3k+ that a PROPER M57 conversion will cost you would buy a lot of petrol..................
mattrs
Granted, but it would be a beast... perhaps as quick as one with s50 or m62 conversion and more economical!?
redcar
Put a 335d/535d engine in...Twin sequential turbo with 350+bhp...
Now THAT WOULD BE FUN/ECONOMICAL
I'd still prefer an N/A Screamer though. A power range of only 2k RPM is a bit boring.
My M52 2.8 converted chromie was quicker than most S50 conversions, and I never had to put derv in that
TouringTash
Are diesel engines heavier?
Greater forces inside the pots for one must be adding weight to the crank no?
318i Touring
redcar
I think a diesel engine would work out quite a bit heavier than it's petrol equivalent. Turbo and intercooler and other bits all add weight.TouringTash wrote:Are diesel engines heavier?
aze30
but that shear torque buzz is worth it no???redcar wrote:I think a diesel engine would work out quite a bit heavier than it's petrol equivalent. Turbo and intercooler and other bits all add weight.TouringTash wrote:Are diesel engines heavier?
