Glass removal
Hoobs
Post Thu Jul 12, 2012 9:23 am
Just stripping shell prior to sending off for cage and need to remove all the glass.
Apart from using a hammer are there any tips / techniques to make it easier?
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
BATTS91
Post Thu Jul 12, 2012 9:34 pm
no hammers ect required for front and back take outer middle bead out an they pretty much push out .
Rear quarter windows if not popouts lay in back and push out with your feet :)
Hoobs
Post Fri Jul 13, 2012 9:14 am
Thanks.
It all came out far more easily than expected tbh. Only downer was the front screen which developed a tiny tiny crack. :evil: Big enough to render is useless though.
2002
bimanut
Post Fri Jul 13, 2012 2:27 pm
BATTS91 wrote:no hammers ect required for front and back take outer middle bead out an they pretty much push out .
Got to remove some pop outs soon,any tips cuz i dont want to break them :(
milescook
Post Fri Jul 13, 2012 6:01 pm
Took my windscreen out after some tips very easily. It stayed under my bed for 2 months while the cage was fitted.
When putting it in the other car to take to a garage, so they could put it back in (the bit more difficult part), I held it horizontally and the weight of it cracked itself... top tip there hold them upright when moving them about!
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
BATTS91
Post Fri Jul 13, 2012 8:40 pm
first id undo the two screws at the hinge ,
Then theres 2 8mm nuts 1 behind the circle bung and 1 behind the hook at top , you will probs need 1/4 " socketand extension , whilst undoing second nut hold window as precaution but shouldnt fall out ;)
bimanut
Post Sat Jul 14, 2012 6:57 pm
Ta very much :D
BATTS91
Post Sat Jul 14, 2012 8:33 pm
No problemo sir
