broken head bolt in Engine block
Fraz06
Post Wed Jul 11, 2012 10:04 pm
Hi guys,
Was removing the cylinder head on a m40 engine to replace the head gasket and i accidentally snapped a head bolt which is now stuck deep in the block. I am doing this at a lock up garage that has not got any means of electricity and im unable to drill the broken bolt out. Has anybody got any idea's what else i could do to try and remove the broken bolt? thanks in advance everyone.
sweep
Post Wed Jul 11, 2012 10:20 pm
Put another motor in would be the easyest way
zaust
Zone day release
Unless your very good with your tongue you will need to drill it.
M30 Tech 1 Touring on gas.
Post Thu Jul 12, 2012 12:17 am
Unless the break has burred the thread, the remains should be completely loose in the hole.
Try superglue on the end of a pencil that has an eraser on it, and if that doesn't work, try a special left handed drill bit in a cordless drill. As soon as it gets into the bolt it should spin it out.
scjimbo
Post Thu Jul 12, 2012 8:04 am
This is the same way I did it.
