Starting an engine whilst its out of the car?
jmc330i
Post Wed Jul 11, 2012 1:00 pm
Got an M40 I want to run up and check before going through the hassle of digging out the engine crane and actually fitting it.
It's sat on a cradle at the moment, so wanted to run it up where it is.
It's got the complete loom attached, but what wires/pins do I need to connect at the c101 to get it running?
James
'91 325i Sport
'93 318i touring 16v
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Jul 11, 2012 1:10 pm
You don't need anything at the C101. Just bridge a wire from the battery + to the coil, and start from the diagnostic plug.
http://www.e30zone.net/e30zonewiki/inde ... re_To_Coil
http://www.e30zone.net/e30zonewiki/inde ... Plug_Start
Post Wed Jul 11, 2012 2:02 pm
Yep, you can also go through the C101 but basically, earth straps, live into the loom, ignition and start
jmc330i
Post Wed Jul 11, 2012 11:16 pm
Cool, thanks guys. So basically, I give the starter and coil 12v, bridge the DME relay to get the ECU working and bridge pin 11 and 14 of the diag plug to spin the starter. Once its running, disconnect pin 11 and 14 and it will happily sit there idling?
James
'91 325i Sport
Post Thu Jul 12, 2012 12:06 am
Applying 12 volts to the coil will backfeed to the ECU, switching it on, and in turn switching the DME relay on, so you won't need to bridge it.
jmc330i
Post Thu Jul 12, 2012 7:47 am
Ah, that makes sense. Thanks Brian 8)
Brian, Ive sent you a PM, but not sure its gone through.
James
'91 325i Sport
