1994 L Reg 316i touring, does this have 325i suspension.....
M7STN
Post Mon Jul 09, 2012 1:45 pm
Hi Folks,
As per title does this have 325i suspension and brakes?
I've just bought an L reg 316i touring and have been told it has the above due it it being a late model?
Thanks,
Stephen
polsta
Post Mon Jul 09, 2012 1:48 pm
youd probably be better off taking some pics of the shocks and springs and posting them up
TPS
Post Mon Jul 09, 2012 1:51 pm
All Tourings had the 51mm Struts, which were standard on the 325i I think?
The Brakes I don't think are 325i, the calipars & disks are smaller.
Duke137
Post Mon Jul 09, 2012 1:58 pm
Springs, shocks and brakes will all be suited to the smaller 4 cylinder car.
As TPS Said, they have larger struts and larger rear calipers and discs (as opposed to 316 saloons that have rear drums)
Post Mon Jul 09, 2012 1:59 pm
It left the factory, as did all UK tourings except a few very early 318s, with identical suspension and brakes to all 325 saloons, except for weaker front springs (to suit the lighter engine) and rear brake callipers with slightly larger pistons.
325 tourings are the same, except for having stronger front springs, and sharing alloy control arms with the M3.
Quaser
Post Mon Jul 09, 2012 2:41 pm
Do tourings have abs?
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Jul 09, 2012 4:54 pm
Not all of them. My 1989 320i one didn't.
TPS
Post Mon Jul 09, 2012 6:39 pm
Both of mine do, I've seen plenty that don't have ABS, it was a £553 option IIRC.
TPS
Post Tue Jul 10, 2012 6:25 pm
Brianmoooore wrote:except for weaker front springs (to suit the lighter engine) and rear brake callipers with slightly larger pistons.
What would happen if you put the 6 cylinder springs on a 4 cylinder car?
Barx325i
Post Tue Jul 10, 2012 6:29 pm
just as you would imagine, it'll sit high & boing about like a car with incorrect springs..
TPS
Post Tue Jul 10, 2012 6:37 pm
I don't think I've ever travelled in one, with the Incorrect Springs on.
Barx325i
Post Tue Jul 10, 2012 6:40 pm
me neither, but I did have the misfortune of buying a 320 with 4 pot springs up front, it looked great, but didn't agree so much with speed bumps - I think the dampers were shot also..
Post Tue Jul 10, 2012 11:43 pm
Not so much difference as you might think. For instance, a 316i auto with aircon uses the same front spring as many M20 models.
