tourer-dan wrote:Brian, these wires taped to the loom near the footwell speakers are the wires which terminate by the tweeters, yes? So is there somewhere to plug these to make them 'live' or do I cut off the plugs and wire them into the footwell speaker circuit? Do the OEM tweeters (which I've got, but not wired up) need a separate crossover too, or would this have been part of a little wiring set I presume ran from the speaker terminals in the footwell to the nearby plastic connectors on the wire running up to the tweeter?
(I hope all this ,makes sense to you!)
Yes, the wires taped in the footwell are the wires that go to the mirror tweeter pods, via the door plug and socket, of course.
The OE tweeters need a crossover unit of some kind to be fitted by the footwell speakers. Presumably there is/was a BMW OE unit available, which fitted the blue connector.
The only E30 I have ever had with the OE pods is my wife's touring. The tweeters in this had been connected straight across the terminals of the footwell speakers, and were consequentialy blown.
