refurbing head lamps
polsta
Post Fri Jul 06, 2012 12:34 am
im refurbing my head light units
ive stripped them down and am getting the metal plate section blasted and powder coated , and new ajusters etc, whats the best way to refurb the backs of the actual head lamps ? the metal part, 2 of them are a bit flakey/corroding, so they all need a rub down, is there anything specific to use or not to use and for pant is it just a heat reistant spray paint ? or is there a better way ?
also the headlight rings- anyone know what paint is best for an oem look ? when brand new at the factory, would they of been a real nice bright silver, or a dull silver like they look now ?
also quick q- are pre facelift,and facelift, head lights the same ? either the whole units, or just the actual "lamps" or whats different ? or are the backing plate sections the same, but different ajusters or what,i cant remember
Post Fri Jul 06, 2012 12:40 am
Prefacelift units are Shite for light output, you better of putting in some Bulleye ones in.
Heatproof paint os ok, but I normally spray Matt black on top of it as the heatproof, once dried, comes out a dark grey.
polsta
Post Fri Jul 06, 2012 12:47 am
ok thanks
i do have in my garage , some facelift units , are the actual "lamps" the same fitment ? i do want to keep the car original looking, so dont want the latter ajusters or whatevers different
why do they differ ? cant the bulbs just be changed ? they are all matching original hella units, not bosch , wouldnt the facelift bosch detract from originality ?
Post Fri Jul 06, 2012 12:52 am
shotblast and powdercoat the buckets/lamp holders black, powdercoat the rings silver new/refurbed adjusters and possibly new main beams (£22 each via GSF) with fresh bulbs,
they will be far better than facelift lamps if set up correctly they will really set off the front end of your car :D
fitting bullseyes means chopping up the wiring when it should be plug and play....
Post Fri Jul 06, 2012 12:54 am
Does your car have prefacelift lamps??
Cleaning them is a bitch as all the housing is metal and usually rusted.
Steve bought a new set, about £500 from dealers if tyou want to keep oem.
Cleaning the inside of the lamps is a pita on those.
Changing the bulbs will help some, but n HID's
polsta
Post Fri Jul 06, 2012 1:02 am
thanks toplesss-thats the job i want to do, just refurb them , what are the "new main beams" is that the bit that you remove from the back of the lamp that holds the bulb ? , im loooking on gsf-can only see the actual headlights, or bulbs ? any chance you can post a link to the part you mention please ?
yes rav they are the original pre pacelift light units, they are not badly rusted and all fully striped down ok, obviously old ,the metal plates are a bit rusted but will blast and powder coat nicely,no rot on them just surface corrision, and the back of 2 of the actual lamp units have some corrosion
i just want to fully refurb the units so as good as new
Post Fri Jul 06, 2012 1:18 am
new headlight
http://www.ebay.co.uk/itm/Headlamp-RH-B ... 58915f5b23
only showing RHS but i'm sure they stock both new glass and bulbs work great when pointing in the right direction....
here's mine... i'm a bit homo when it comes to new bits :o:
polsta
Post Fri Jul 06, 2012 1:37 am
they look great, what i want to achieve !
if i ge the actual new headlight ,as per the link , what make/brand are they ? just a generic plain one ? wouldnt i be better off keeping the original hella unit ? , all 4 are matching hella lamps and the originals
what silver are your rings ? just "silver" and nothing in particular ?
polsta
Post Fri Jul 06, 2012 7:43 pm
some pics
stripped down
the corrosion,2 were good and 1 was worse
gave them a rub down
and ive put some of everyones favourite FERRRRTAN :D on the bits, to leave a cple of days
so what next...mask them,and heat proof paint ? no primer or can you get heat proof primer ?
johnl320
Post Fri Jul 06, 2012 7:56 pm
You had all the plastic caps off em yet? mine were bloody tight
polsta
Post Fri Jul 06, 2012 8:04 pm
what caps ? the little ones that hold the ball joint part of the ajuster ? or th end caps ?
how much are the ajuster screw parts ?
dont suppose anyones got a list of the part numbers/prices for the fittings ? (pre facelift) , although they werent bad and all worked ok, but il fit new ones i think
BATTS91
Post Fri Jul 06, 2012 8:09 pm
the plastic backs you take of to replace the bulbs i think , they can be a fooker
Kedge
Post Fri Jul 06, 2012 8:33 pm
Are they bullseye headlights? The have a completely different back to my prefacelift headlights!
Instagram - Kedge85
polsta
Post Fri Jul 06, 2012 8:47 pm
this is them before being removed , all hella , what ones are they ?
can you buy these brand new still just single lamp units ?
how can you clean inside ? an air line or something to give them a blast out ? or do you think if bulbs etc remove you could swirl some liquid arund in there ?
Kedge
Post Fri Jul 06, 2012 8:54 pm
They do look like pre-facelift headlights, probably exactly the same once the plastic backs are off then. All the ones i've seen have metal backs, although i can't remember what the 2 Tech 1 Sports i've had had fitted.
Instagram - Kedge85
mcbonio
Post Fri Jul 06, 2012 9:07 pm
Had a look at mine the other day, no rust.! Although the glass has lost its gleam and looks a bit cloudy / milky. They are the only bit thats letting the front end down now.
Anyone know the best way to rejuvenate the glass? What products there are ect..?
polsta
Post Fri Jul 06, 2012 9:12 pm
Kedge wrote:They do look like pre-facelift headlights, probably exactly the same once the plastic backs are off then. All the ones i've seen have metal backs, although i can't remember what the 2 Tech 1 Sports i've had had fitted.
what do you you mean metal backs ? the backs are metal ? bit confused, they did not have any plastic backs, you can see in the 1st picture everything stripped from the unit , or if you mean the actual plastic inner bay cover bits, they were removed a while ago before the lights were removed
Cloggy Saint
Post Fri Jul 06, 2012 9:15 pm
Fill them up with soapy water, give it a swirl and let them dry completely, makes a world of difference.
polsta
toothpaste or t cut , thats what ive read , obv try toothpaste 1st and see how it comes up, thats what im going to try, give it a go and take before/after pics , scub it with a cloth then rise with water
or theres a machine thing/some sort of attachment that can do it i saw via google
polsta
Post Fri Jul 06, 2012 9:17 pm
Cloggy Saint wrote:Fill them up with soapy water, give it a swirl and let them dry completely, makes a world of difference.
cheers il try, one of them has some dust in, i dont really want to buy new lamps or replace, i like the matching hella and "made in germany" so want to get these as good as i can
is it best to just leave to dry, or maybe blast them out 1st with an air line ? to maybe stop water marks ?
Kedge
Post Fri Jul 06, 2012 9:21 pm
Instagram - Kedge85
Cloggy Saint
Post Fri Jul 06, 2012 9:23 pm
I did mine during winter and left them upside down on a radiator for a day or 2, they came up spotless.
johnl320
Post Fri Jul 06, 2012 9:26 pm
I meant the caps in Kedge's pic, as above I left mine on a radiator for a day or two. Brasso works quite well on the glass too.
mcbonio
Post Fri Jul 06, 2012 9:27 pm
Gonna go try some toothpaste before it gets dark.!
polsta
Post Fri Jul 06, 2012 9:29 pm
mcbonio wrote:Gonna go try some toothpaste before it gets dark.!
take some pics before and after- il be interested to see, saw it on google looked good, but that wasnt e30 lamps
cheers lads ^^ ,once painted il give soapy water a go , ive compiled a list from real oem of whats needed...
No. Description Supplement Qty From Up To Part Number Price
10 Adjusting screw 4 09/1987 63121370857 $9.92 Cat=No
09 RUBBER BUSHING 4 09/1987 63121369833 $2.34 Cat=No
04 Tension spring 2 09/1987 63121362037 $3.00 Cat=No
18 Body nut ST6,3-1-ZN 6 09/1987 07129925742 $0.25 Cat=No
19 Screw, self tapping 6 09/1987 63121352070 $0.62 Cat=No
06 Adjusting screw 4 09/1987 63121373571 $7.30 Cat=No
05 Bush 4 09/1987 63121364940 $4.97 Cat=No
polsta
Post Fri Jul 06, 2012 9:51 pm
in my pictures there, the little push in "holder" plastic thing, that the ball joint of thew ajusters push in to, can anyone help with a part number for that ??? the white plastic bit in nthe bottom of the one on the left
Post Fri Jul 06, 2012 10:14 pm
Have you tried ECP E30Zone account? Im sure matt can get some of these adjuster parts
Ignore Rav and his bruv spec facelift light conversion :wink:
Early lamps with good reflectors and lens' are better than most facelift lamps, the lights on my 50k mile chromie are better than any facelift ive had in the past. Take note of the lens' though, if they are peppered with sand/grit chips you wont ever get good light output and would be better off buying new units.
There are two types of prefacelift lamps, early early ones have steel bulb covers, and the later early ones have plastic bulb covers like the above picture
adit
Post Fri Jul 06, 2012 10:26 pm
...if they are peppered with sand/grit chips you wont ever get good light output and would be better off buying new units.
:chuckle:
can glass be compounded/polished?
correct. i have several pairs of both types Carl
[quote="bss325i"]
Post Fri Jul 06, 2012 10:35 pm
Some specialists can get rid of scratches on windows etc, ive tried the likes of G3 and similar on headlamps before and I wouldnt bother again, that glass is fooking hard!
Post Fri Jul 06, 2012 10:57 pm
Karl, I'll take a look in the morning, I think I have some really good prefacelift ones.
Ignore the Haters above. :wink:
Post Fri Jul 06, 2012 11:09 pm
Post Fri Jul 06, 2012 11:21 pm
DanThe wrote:Image
He;s doing something Different, is that really that wrong :wink: :D
snakebrain
Post Sat Jul 07, 2012 11:27 am
polsta
Post Sat Jul 07, 2012 12:01 pm
excellent thanks for that link ! what a super job he did there
so he dipped in rust remover, if you look at his head lamp rings, and mine...mine are not "chrome" are they ??? my 318is ones were not actual chrome either but painted by the look of them ? them rings came fantastic after a dip in that stuff
he also paints with "etch primer" then paints , he doesnt use heat paint ?
snakebrain
Post Sat Jul 07, 2012 12:04 pm
Why would you need heat paint? They shouldn't get that hot. I did some lamps with Smoothrite Silver and they were fine. I'd recommend replacing most of the fixings, just because it gives much cleaner looking final product and, frankly, is a lot easier than endlessly dicking round with a toothbrush cleaning them!
