30m or 35m (lowering)
ameetgill1
guys whats the best and the smoothest options in terms of look, size and stability
either of those drops are good enough not to compromise the ride comfort,what shocks are you going to use ?
+ a yard full of scrap turds
ameetgill1
http://venommotorsport.com/prod_categor ... versal=Yes
what do you recommend in the above?
will they both go over bumps and plus i am looking for 16inch alpina wheels so will they be ok.
G-Bear
Bilstein and H&R are a popular choice on here. If you go for Bilstein's whole kit (dampers and springs) they use Eibach springs which I think are said to be not quite as stiff as H&R springs.
I've got Eibach springs, they make for a sturdy ride but not too much of a bone shaker.
Have a floss through the below link, that should give you some decent info..
http://www.e30zone.net/modules.php?name ... os+lowered
ameetgill1
thanks for that i reckon il go for h and r. is there anything else i need like shocks or will the kit be sufficient
Morat
Don't forget roll bars while you're there.
