as above really got a tech 2 steering wheel too put on my car but i cant get my tech 1 off..
any one shed some light?
newbie needing help... how to remove tech 1 steering wheel
Steve
If the nut is undone, make sure the steering lock is off
Rtaylor2208
Remove the BMW emblem using a very small flat head screwdriver, that will reveal the bit nut holding on the steering wheel. (22mm I think). Remove the nut and disengage the steering lock and the wheel should just pull off of the splines.
Fitting the tech 2 is the reverse.
Rtaylor2208
See above
Vish
thank you very much i thought i had to remove the bmw badge but didnt want to break it
