hi All,
Did anyone try to make their convertibles more rigid
with an x-brace bar and did it work.
many thanks.
Peter.
Can a cabby be made more rigid?
- E30 Zone Meets/Events Team
There should be a bar underneath on the cab.
I have a strut brace and have noticed a difference, also in an M30'd cab.
Hardtop helps too.
Hardtop helps too.
e30s50b30
IN MY E36 M3 THE HARD TOP HELPS SO NOT SURE IF ITS THE CASE IN THE E30 BUT THE STRUT HELPS TOO
PeteE30Tourer
Where should this bar be exactly?Rav335uk wrote:There should be a bar underneath on the cab.
Back behind an M20, but now I can hear it better.
On the 2 chassis rails.PeteE30Tourer wrote:Where should this bar be exactly?Rav335uk wrote:There should be a bar underneath on the cab.
Looks like an "S" shape
PeteE30Tourer
Thanks Rav/Brian - I'll check mine is there when I next get her up in the air. Dont remember seeing it when I last spent some time underneath her.
bmw335icoupe
thank you all for the input.
I'll go for the strut brace first.
Is there any particular strut brace make, which will do the job best?
many thanks,
Peter.
many thanks,
Peter.
Ianb
The S shaped bar is bolted at the front of the heatshield by the gearbox and effectivly holds the shield up. It's stronger than it looks.
