what do you do when it's time to get your brakes done?
Captain_Birdseye
just wondering best/cheapest way. Need my rear pads and front discs and pads doing. 1989 320i 4dr.
suchy
- True Zone Relic
Cheapest way is to do them yourself!!
Captain_Birdseye
well I've asked a guy on here for a price on the parts. Just having a look at the wiki now - difficulty 1 - 10?
Mo13
Get the discs and pads from http://www.eurocarparts.com/brakes and use discount code DP30 (30% off)
harry_p
Difficulty 1-10?
About a 3.
Higher if something is more awkward than it should be, I.e calliper bolt is stuck or breaks, disk screw rounded etc.
About a 3.
cheers,
harry
harry
Jim320i
- E30 Zone News / COTM Team
Too much of an easy job not to do yourself to be honest!
Duke137
The words Cheapest and brakes in the same sentence always makes me chuckle
Having said that, cheapest isn't always the best approach for any maintenance full stop.
Good luck
Good luck
Grrrmachine
- E30 Zone Wiki / Team Member
If you've got socket sets and an extension bar it's difficulty level 1.
If you've got three spanners and a hammer, it's difficulty level 8.
It all depends on whether the calliper bolts want to come off or not. That's the only difficulty.
BATTS91
make sure you have alan sockets for 3/8 ratchet to take the calipers off , flimsy cheap ones that dont go on a ratchet are never good in my experiance , easy job
Motorhole
Turn the front wheels on full lock one side at a time and just loosen the front caliper bolts with the car on the ground first. Big extension bar, they are either coming undone or they are breaking - the latter, easy to get replacement bolts from BMW. Helps if you soak them in penetrating fluid for 30 mins or so first but be sure not to get any on the disks if you're not replacing them. Once you have loosened them a turn, you can jack the car up and get on with the job nice & easy.
iceox
euro car parts and halfords pro toolset and jobs a jobbed
Get them from here: http://www.carparts4less.co.uk/ (same part numbers, same warehouse as eurocarparts) and use discount codesMo13 wrote:Get the discs and pads from http://www.eurocarparts.com/brakes and use discount code DP30 (30% off)
CP5LESS, CP10LESS, or CP15LESS, for 5%, 10% or 15% off, if your bill comes to £50+, £75+ or £100+ respectively.
Pagid pads are OE, and the matching Pagid discs are faultless.
Don't forget the pad wear sensors if they are worn at all.
Difficulty level depends more on your competence, a lot of people can change brake pads, but then again there are a lot of people that can round off bolts, hammer pads into rusty brackets and generally make a right fking mess of the job
Captain_Birdseye
Thanks. I've decided to source the bits from one of the suggested websites - thanks for codes - and get the local garage to do them. Normally I'm not too bad at attempting this stuff but I don't have the time atm cos I'm just about to start 2 weeks of labouring long hours, maybe not a good time.
