E30 S65 powered chromie
Karan
Post Tue Apr 24, 2012 8:16 pm
f0xy wrote:None of the clio servos have an adjustable clevis side. My 182 one was the correct length for stock pedal position, but i guess there is nothing stopping the clevis being cut off and a thread put on the rod, then a clevis wound on with a locking nut to get some adjustability
Yeh was gonna do that, but I think holding the rod will threading it may be tricky, will give it a go anyway
Karan
Post Mon May 07, 2012 5:23 pm
Column has been lowered, clutch pedal bodged, seat mounted using some bodged up recaro r32 rails with my spg copy seat. Driving position is fantastic now, just finalising the throttle which will be the s14 top hinged one
Getting there....
Demlotcrew
Post Thu May 10, 2012 8:41 pm
You could always use mild acid to prep the bay, easy to apply and easy to remove :)
Karan
Post Mon Jun 04, 2012 5:56 pm
Engine bay painted, now the mammoth task of prepping the interior
crossie
Post Mon Jun 04, 2012 9:45 pm
you fitting a cage to this?
Karan
Post Mon Jun 04, 2012 11:07 pm
Might do not sure yet.....
crossie
Post Sat Jun 23, 2012 9:26 pm
you got this finished then?
Karan
Post Wed Jun 27, 2012 10:31 am
Middle of buying a house at the moment so bit busy, but welded up the engine mounts ( previous just tacked) and stripped ancillaries from engine and cleaned last night., the engine was filthy due to rocker cover leakage.
Basically I've been putting off the horrid task of of Cleaning /prepping the interior. Also have the passenger jacking point, drivers side rear inner arch tub, and rear passenger footwells welding to finish, but it's all very minor. Maybe tonight. I'm still umping and arghing as to whether or not to just slap a custom cages 6 point weld in, as they're only bout £450 for the DIY kit.
My e46 quick rack has also turned up so can finalise the steering column now too.
Kos
Post Wed Jun 27, 2012 1:53 pm
Karan wrote:Middle of buying a house at the moment so bit busy
has it got a nice big garage :D
Karan
Post Wed Jun 27, 2012 3:32 pm
Double, for storing and maintaining my s14, gonna keep pressing on with the projects at my parents as we're fortunate enough to have laodsa room there, and can make plenty of noise also.
danthee30man
Post Fri Jun 29, 2012 11:52 am
how are you going with the suspension ? are you changing to the 52mm struts ?
looking good tho !!
Karan
Post Mon Jul 02, 2012 5:26 pm
Gonna go for the bc coilovers with 12/12 springs. Rear disc arms and 325front brakes, yellow stuff pads all round. Will oeob just keep the smaller front hubs as bc do a fitment for this and it's the same damper as the larger version.
On another note I stripped the engine yesterday completely. I'm still not sure why I did but I did anyway. I think I will rebuild this s14a engine to the following spec and then stick it in my s14. That has a stock internals s15 lump in it which I'll then put in the e30. I have big plans for 500whp+ in the silvia and need a strong engine for it.
Anyway engine spec will be
Wossner rods 86.5mm 8.5:1 comp
PEC h beam rods
Arp headbolts
Acl race rod bearings
Acl race main bearings
Cosworth 1.1 hgasket
Rotating assembly to be balanced
Stock crank
Head work yet to be decided, prob go with tomei poncams and tomei valve springs. I would like solid lifters or a vvl head to eliminate the rockers but can't afford that at present.
Andeep
Post Thu Jul 05, 2012 6:18 pm
1 step forward and 2 steps back! will be mega awesome when its done tho!
rcs_888
Post Sat Jul 07, 2012 2:44 am
Hey man nice conversion i like the pedal pox with the moved Booster, im in the middle of an RB conversion and im having massive issues with the booster being on the LHS so i might have to start cutting the batt tray and move the booster lower for more rooooom :)
Karan
Post Tue Aug 28, 2012 9:43 am
Scrap the previous engine idea. The engine was stripped and I decided to just rebuild it and stick it in the e30. There is a rather more special engine going in the silvia now.
The engine was stripped and everything was found to be in spec apart from exhaust valve guides. Head was resurfaced 0.004'. Rehoned bores, everything cleaned and blown through. Block surface was just cleaned. So far I've assembled bottom end rotating assembly with acl race bearings and NPR rings. Supertech guides were also fitted.
Karan
Post Thu Oct 25, 2012 11:34 am
Still not stuck the head back on yet, still got to lap the valves and shim it properly, which is a bit tricky on sr heads.
In the mean time I have ordered a custom cages clubman 6pt weld in cage so I will be getting to work installing that when it arrives in about 10days time. The cpl small rust repairs will also be done and ill then paint the whole car myself..... 8O
Demlotcrew
Post Thu Oct 25, 2012 12:24 pm
Karan
Post Mon Mar 11, 2013 9:17 am
So the shell prep carried on, with few rust repairs and a lot of cleaning g of dirt inside and glue from sound deadening. I want to do this before I weld the cage in. Also cut out spare wheel well and rear bulkhead areas for cage to get through, this will be repelled after to recreate the firewall.
Made a spit on bearings to help spin the car
A little cleaning every night this week should have it ready for the cage by weekend hopefully.....then prep and paint the whole car.
crossie
Post Thu Mar 14, 2013 10:29 pm
coming on great!
Karan
Post Mon May 13, 2013 5:36 pm
Some pics of rear half of cage getting sorted. Lots of in and out.....
Karan
Post Mon May 13, 2013 5:37 pm
Demlotcrew
Post Mon May 13, 2013 5:38 pm
Looking good hack! :cool:
Post Mon May 13, 2013 5:44 pm
Harj,
where did you gett he pipe work for the cage?
Karan
Post Mon May 13, 2013 5:50 pm
Cheers Andrew.
It's a custom cages clubman spec.
redcar
Post Mon May 13, 2013 5:51 pm
Rav335uk wrote:Harj,
I'm Harjun lol. This car is my brother's (Karan) SR E30.
The red M52 one is mine :)
Post Mon May 13, 2013 5:53 pm
LOL, all Indian though LOL :D
crossie
Post Tue Jul 09, 2013 12:48 pm
any progress?
dirtee-herbert
Post Fri Sep 13, 2013 2:35 pm
crossie wrote:any progress?
+1
NEED MORE PLEASE :cool:
Karan
Post Mon Feb 15, 2016 3:27 pm
OK let's have a complete direction change with this and go crazy!!!!!
I came across a chap who was selling engine box and electrical gubbins from a e92 m3. Having lusted after one of these as a possibility for my S14 track car I knew I had to get it and the e30 seemed the right home for it.
A deal was done and we hired a huge van to go collect it. The engine was stil on the subframe and was picked up and dropped into the van in a few minutes.
Everything was then unloaded at my house where the shell currently has resided for the past couple of years with very little activity.
With these engines a lot of other body modules have to be present for the engine to work properly without error codes so I got pretty much everything of the the car loom and cluster and all modules etc. As the body mods will take place first to fit the engine And then the body will
Likely have to go to paint I decided to make a frame to get the engine and box to sit on and get running on whilst the body is away or getting modded. I then removed the air con and pas pump along with temporarily removing the engine loom
Itself. The power steering will be an electro hydraulic pump likely placed in the cabin.
Air pump and air recirc thingy removed- this is for
Emissions to heat up the cats quickly
Found an oil leak from filter housing area so cleaned that and will
Change gasket
Head seemed tidy
I knew I was going to have to cut and remake a lot of the tunnel and bulkhead area to get the engine far back as possible so I made a bar to support the bottom of the shell and prevent inward collapse.
Then I cut the area out , likely will need more later
I did all the over the weekend so really happy with speed of progress
Next stop engine and gearbox mounts!!
manse73
Post Mon Feb 15, 2016 3:49 pm
I like the look of this. What a big step to reviving a project. Good luck and keep the updates coming
bruv chariots rule
Kos
Post Tue Feb 16, 2016 12:05 am
Karan will be back in an e30 with a big heart :D
Post Tue Feb 16, 2016 8:44 am
Fantastic change of direction! :D
gareth
Post Wed Feb 17, 2016 8:27 am
Bonus man points +1000 :D
Karan
Post Mon Feb 22, 2016 8:45 am
Managed to get some time to crack on today
Managed to get the engine in and into a provisional position. It's just the height of it I need to fine tweak now as I obviously want the stock bonnet to shut but don't want the sump dragging too low. The s65 plenum is so tall this may be a challenge.
Karan
Post Mon Feb 29, 2016 10:44 pm
The beginnings of the engine mounts this evening
Got cutting/drilling some 6mm plate for the block side. This will then have arms which will join into a tube which will have the 40mm poly bushes in it. A single 12mm bolt will then pass through this.
