25 kg balance
jonny323i
what the hell is this
http://www.ebay.co.uk/itm/bmw-e30-25kg- ... 4d027a4b53
Touring for life
that fits in a cab's drivers side bootwell and prevents scuttle shake i think.
+ a yard full of scrap turds
jonny323i
thats one hell of a chunk to be carrying around
Touring for life
It's a harmonic vibration damper and BMW put it there for very good reasons.
rav chucks his overboard when in shallow water
jonny323i
so its not just a chunk of metal then
Touring for life
jonny323i
and his engine in deeper watermagpie wrote:rav chucks his overboard when in shallow water
Touring for life
manse73
can you explain this pleasejonny323i wrote:and his engine in deeper watermagpie wrote:rav chucks his overboard when in shallow water
Sebring grey motorsport convertible
jonny323i
m30 boat anchor
Touring for life
Mo13
I belive this is in all cabs to compensate for the B and C pillers.
ajay
If the battery was relocated to the boot would this compensate for the vibration damper,or would the battery suffer any negative effect?
FinalD
What I find interesting about this is that it is only on the driver side, the passenger side is clear of any weights. Surely if it is to compensate for the pillars they should have installed a weight either side?
The bolts that tie it into the car are utterly amazing though, something like 6 to 8 inches long. The bad thing about it is that water can get in under it and can't drain out of the well and so could rust your rear wing away.
No negative effects, the E36 6pot cars all have the battery in the boot as standard. I much prefer the battery there in all honesty. As for replacing the dampener/balast, I'd be weary of doing it if the battery wasn't 25kg. I don't know what the true reasons and effects the weight of the balast/dampener are so can't really comment too much on swapping it for a battery or removing it.ajay wrote:If the battery was relocated to the boot would this compensate for the vibration damper,or would the battery suffer any negative effect?
Allegedly, BMW considered placing the battery there at the prototype and development stage, but found that the vibrations damaged the battery.
The weight isn't mounted rigidly, but sits on resilient mounts.
Just realised that this thread is prompted by one for sale on ebay, not the usual "I've just discovered this massive weight in the back of my cab" that we usually get.
Can't see him getting much luck with the sale, although it's worth about £3.50 as scrap!
M3 convertibles have the battery in the boot, and the weight . E36 convertibles also have a similar set up though interestingly BMW specified that the E36 convertible battery should be a special 'vibration proof' type.
pukar
Cloggy Saint
jonny323i
I thought so lol
Touring for life
Ianb
I've removed this from my cab and don't have any ill effects at all.
Duke137
I am trying desperately to work this out, please put me out of my misery???pukar wrote:when r kelly's girlfriend got rid of hers, he wrote a song and made a lot of money
I may be being dumb here, it's not often but from time to time it happens lol
FinalD
I guess it is something along the lines of junk in her trunk?
pukar
Mo13
Shame it is not factually correct !
