Think Ive bitten off more than I can chew!!!
Mo13
Post Tue May 08, 2012 2:05 pm
As a newbie to e30s I rushed into buying my first e30 325i cab”¦..My uncle has owned 3 e30s in the past and Ive always wanted 1 found this and thought it was a bargain and grabbed it at £650 only this weekend I have had a proper look at it under the light in the booth, got it so I can work on it evenings and weekends looks like I have got to do more that I thought!
Wanted to get it ready for the very short British summer, now the chances are looking slimmer
The ramp was busy so I couldn’t get any pics from underneath (will try and get some this week) but as far as I know I need to change:
Subframe (trailing arm bracket broken)
Subframe and trailing arm bushes - sourced powerflex bushes from fellow zoner Chris (bodger) *Cheers mate!
Rear ABS sensors and oil presure sensor ”“ sourced from fellow zoner Byron (maggspower) *Cheers mate!
Tie rod ends/bushes and what ever gets rid of the play in the steering wheel ”“ its like your behind the wheel of a ship now
Rocker cover gasket
air intake pipes
MUCH NEEDED SERVICE!!!!! (hasn’t been serviced for 3 years)
And I'm sure there will be a few more surprises along the way”¦”¦”¦.
Now for all the bad bits”¦”¦.
Gap when closing the door, unless you push the window in while closing the door:
Rust under the drivers door:
Rust under the rear bumper and a very wobbly exaust:
Rust bubbling through on rear arch:
Cracked fogs:
Headlight wiper missing:
SHOT UPHOLSTERY as per http://www.e30zone.net/modules.php?name ... highlight=
The bumper lip has been bodged on so I guess I need that too”¦.
suchy
True Zone Relic
Post Tue May 08, 2012 2:14 pm
Pah, normal E30...
Grrrmachine
E30 Zone Wiki / Team Member
I'd suggest you get the bodywork sorted before you do anything mechanical to it. The subframe and trailing arm bushes, while a pain, are certainly doable in a weekend if you know how to approach it, and the other mechanical stuff would class as "niggles".
But those rust points could turn out to be a lot nastier than they look now. The rust at the bottom of the door will be inside the B-pillar, and will have infected the floorpan and inner sill, requiring quite a bit of surgery to put right. It also looks like your rear valance is rusting between the lights and bumper on both sides and if so, those joints will have to be separated and cleaned, and possibly a new valance put in. Add in an arch repair and you're looking at a full respray. The only benefit is that being a cabby, you won't have a roof to paint :D
With the rust you have now, it's essential that you get the seats and carpet out and check the floors and bulkhead for more rust; what you can see is usually the tip of the iceberg:
http://www.e30zone.net/e30zonewiki/index.php/Rust
When clean though, that could be a really cool cabbie.
Post Tue May 08, 2012 2:21 pm
Dont use Powerflex rear subframe bushes. Use Genuine BMW rubber.
Mo13
Post Tue May 08, 2012 2:29 pm
suchy wrote:Pah, normal E30...
Gives me confidence! :D
Mo13
Post Tue May 08, 2012 2:31 pm
Grrrmachine wrote:I'd suggest you get the bodywork sorted before you do anything mechanical to it. The subframe and trailing arm bushes, while a pain, are certainly doable in a weekend if you know how to approach it, and the other mechanical stuff would class as "niggles".
Thanks good idea! just hope its mostly surface ruse **fingers crossed**
Mo13
Blitz wrote:Dont use Powerflex rear subframe bushes. Use Genuine BMW rubber.
Any particular reasons why?
walrus1968
Post Tue May 08, 2012 2:35 pm
you will get it sorted in no time at all..E30's are like constipation ....its hurts like hell for most of the time but a proper rush when it comes out.
good luck mate and im looking forward to some pics when its all sorted !!
:D :D
KEEPING MY "BLURRED PIXELS" TO THE MAX !!! :)
Rich320I
To be fair mate if that’s the extent of the problems, with a cab for £650 that’s pretty good in my humble opinion. Also it gives you the chance to build a good solid e30 as you haven’t paid loads in the first place. :)
powerflex bushes normally give a stiffer rather hard ride in comparison to OEM from what iv seen others mentioning that could be why?!
Post Tue May 08, 2012 3:39 pm
Because half of the reason is hearsay :roll:
Blitz, have you ever driven a car with polybushes????
Nowt wrong with them imo, my cab has every rubber bush replaced with Poly's and there is fook all wrong with the ride. :D
Post Tue May 08, 2012 3:41 pm
I know this car I'm sure, did you get it from Yorkshire ?
aimlessrock
Post Tue May 08, 2012 3:58 pm
Mo, have you had the carpets out and the sound deadening out yet? ... As this will be the real acid test. My cabby was in reasonable nick but once I stripped it the real horrors became obvious...
E30 320i Convertible (1989)
190 Mercedes (1988)
Topblag
Post Tue May 08, 2012 4:01 pm
e30topless wrote:I know this car I'm sure, did you get it from my yard in the Peoples Democratic Republic of T'Yorkshire ?
winkeye
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Daryll
Post Tue May 08, 2012 4:13 pm
My sport makes your cab look mint and I can't do the bodywork so I'm letting a bodyshop teabag me and go balls deep on an extensive restoration. Don't be disheartened it looks like nothing out of the ordinary rust wise. As advised above get the carpet out and have a look under there. Good luck fella but don't throw in the towel just yet.
@e30_daryll
Ianb
Post Tue May 08, 2012 4:23 pm
Looks a nice cabby, I've got a cabby running poly's ( powerflex ) and it rides great so they sb fine. I echo other zoners comments on rust, though I've seen much worse than yours. Check where the innerwing joins the bulkhead ( prob best from under front arch and if you see even the smallest bit oof underseal lifting add some heat & scrape it off ( mine was going here but now fully repaired ). The other thing is check the black portion of the lower front wing where it's stonechipped and if it's good add cavity wax, cabby wings are expensive and it's getting hard to find really good s.hand ones now.
Mo13
Post Tue May 08, 2012 10:40 pm
e30topless wrote:I know this car I'm sure, did you get it from Yorkshire ?
Picked it up from Gravesend in Kent
Mo13
Post Tue May 08, 2012 10:42 pm
aimlessrock wrote:Mo, have you had the carpets out and the sound deadening out yet? ... As this will be the real acid test. My cabby was in reasonable nick but once I stripped it the real horrors became obvious...
Havnt pull them out yet...dreading the floorpan will get some pics up on here when i do.....wish me luck :D
Mo13
Post Tue May 08, 2012 10:44 pm
Daryll wrote:My sport makes your cab look mint and I can't do the bodywork so I'm letting a bodyshop teabag me and go balls deep on an extensive restoration. Don't be disheartened it looks like nothing out of the ordinary rust wise. As advised above get the carpet out and have a look under there. Good luck fella but don't throw in the towel just yet.
Thanks mate I might get somone to do the welding for me, now that my brother in law has a body shop Im looking to tackle the rest of the bodywork myself, with the help of the painter ofcourse :D
Mo13
Post Tue May 08, 2012 10:47 pm
Ianb wrote:Looks a nice cabby, I've got a cabby running poly's ( powerflex ) and it rides great so they sb fine. I echo other zoners comments on rust, though I've seen much worse than yours. Check where the innerwing joins the bulkhead ( prob best from under front arch and if you see even the smallest bit oof underseal lifting add some heat & scrape it off ( mine was going here but now fully repaired ). The other thing is check the black portion of the lower front wing where it's stonechipped and if it's good add cavity wax, cabby wings are expensive and it's getting hard to find really good s.hand ones now.
Cheers mate planning to do a full resprey so I will be looking at all panels for rust
rhubarb
Post Tue May 08, 2012 11:58 pm
There's 3 different grades of polybush available too :)
mr_dink
Post Wed May 09, 2012 12:57 am
Interior and carpets out.
Attack brown bits with wire brush.
Report back with pics.
Mo13
Post Mon May 14, 2012 1:50 pm
Thought I'll get the sub frame swapped over before I start on the body as I had cleaned it and stone chipped.....due to a rusty and rounded drive shaft dolt it call came to a hold. Need to get new set of bolts before I take it off any ideas of dimensions or sizes?
While I had the car on the ramp took a few pics of the underside:
Had a hard time taking the exaust off:
Thought it was the ABS sensor, looks like it’s the bit that goes on to the disks”¦.anyone know what its called or where I can get 1 from?
Grrrmachine
Post Mon May 14, 2012 5:20 pm
Mo13 wrote:
Grrrmachine wrote:I'd suggest you get the bodywork sorted before you do anything mechanical to it..
Mo13 wrote:Thought I'll get the sub frame swapped over before I start on the body
:mad:
e30mtech
Post Mon May 14, 2012 7:11 pm
its just a brake pad wear sensor pick them up on ebay for few quid
aimlessrock
Post Mon May 14, 2012 9:17 pm
That's looks ok, but I would recommend that you remove the plastic wheel covers from inside the front wings ( held in buy a few 10mm plastic bolts) and check the for rust, sub frames etc can all be rebuild or replaced etc, but rust can be a big problem...
I would do the above before you spend any money on this turd. :D
190 Mercedes (1988)
TouringTash
Post Tue May 15, 2012 2:23 am
Carpet out and examine every inch of the floor pan fella.
My little engine swap and a few little patches ended up over 5K with new chassis parts, over 2K of that was just the welding.
318i Touring
walrus1968
Post Tue May 15, 2012 3:05 am
TouringTash wrote:Carpet out and examine every inch of the floor pan fella.
Sounds nasty this :cry: :cry: winkeye
TouringTash
Post Tue May 15, 2012 3:22 am
Least its done now.
318i Touring
Mo13
Post Mon May 21, 2012 5:10 pm
:mad:
LOL decided to do this purely to get the car driving as the rear tyre buckles and it kicks out every time you let the trottle go. sub frame cracked where the trailing arm sits!
Mo13
Post Sat Jun 23, 2012 9:40 pm
Well after alot of dreading I decided to have a look under the carpet and tackle the little bubbling on the driver side rear arch.......guess what...not as good as I first thought.
Seats out
Centre Console out
Flipped up the carpet of the passenger sides....all dry
Flipped up the carpet of the drivers side its moisted!!!! had a little poke around and the screwdriver went through the floor :x h a little rust patch!
Then decided to grind off the paint/bubbling on the arch so I can treat it and all that was comming off was filler!!! :( by now really pi$$ed of with the guy I bought it off had a quick go under the rear bumper wher I saw bubbling and guyss what.....SAME THING!!!
Bumper
The TW4T siliconed the srip on the car when removing a whole load of rusted paint came off
Post Sat Jun 23, 2012 9:57 pm
Well, for a £650 325i cab, what do you expect? It doesn't look that bad - certainly alot better than a £1,900 Tech 2 Sport that I bought, which turned out to be very rusty in many areas. :cry:
Grrrmachine
Post Sat Jun 23, 2012 10:01 pm
I'd say that's par for the course.
Look at this way; if you knew the arches were crusty, you were committing yourself to a respray of the rear quarter anyway, so it doesn't really matter how much rust there is in that area. But now, instead of a fiddly must-be-perfect cut-out around the arch, you can just let in a whole new rear quarter with spot welds and be done with it.
aimlessrock
sorry to hear that Mo...been there mate. As you have your screwdriver out i recommend that you remove the plastic covers inside the driver and passenger wheel arches. In particular check the bulk head, they can rot very badly...especially behind the sound deadening.
i have spent month undoing all manner of bodgery that the last owner had undertaken on mine...
190 Mercedes (1988)
FinalD
Post Sat Jun 23, 2012 10:11 pm
8O
That's really not nice to find there fella, must be properly annoying and gutting. :(
I hope I don't find rust like this when I do my rear arches...so far I've been very lucky with rust.
Mo13
Post Sat Jun 23, 2012 10:24 pm
the resprey is not a problem as my brother has a body shop its just the inconvenience wanted to get the car ready and MOTed in the next 2 weeks so its ready for when the sun pops out.
the most annoying thing is the bodge if it was just rust its expected but hiding it and selling it on is a bummer for the new owner!
Final D - your doing a really good job on yours! enjoying your thread
