ecu chip
scjimbo
I'm thinking of getting an ECU upgrade chip from speedtouch.
How do i find out my ecu code?
Grrrmachine
- E30 Zone Wiki / Team Member
scjimbo
Cheers mate. I looked on that before but mine is a 1987 320. Which as far as i can see comes with one of two systems.Grrrmachine wrote:http://www.e30zone.net/e30zonewiki/inde ... st_of_ECUs
I'm probably just being a plank
scjimbo
Thats what i thought would be best. Is it actually written on it somewhere?diable wrote:or check your ECU as someone may have swapped it over or it may not be compatible with the one you have.
Grrrmachine
If your car is an '87, you're going to have to physically look at the ECU. There's no other way to confirm it.
Grrrmachine
Have a look at this ECU:
http://allegro.pl/komputer-m20b25-0-261 ... 92402.html
You can clearly see the code number on the big sticker, it's the last three numbers you need.
As an aside, I have one of Speedtouch's "Mild" chips for a 320 if you're interested
scjimbo
Oh really? PM sentGrrrmachine wrote:Have a look at this ECU:
scjimbo
Cheers dude. Just off to have a look. The bloke i bought my 30 off was 72 so i doubt it somehow.diable wrote:The ECU is under the kick panel on the drivers side, check it and open it up to see if a chip hasn't been fitted already.
Grrrmachine
You don't have to open the ECU; just look at the metal tabs underneath from the cover that fold over the base (you'll understand when you see it). If those tabs look chewed or scratched, then the cover's been off at some point, usually for chipping. If they're clean, no chip.
scjimbo
Well just had a peek. all looks pristine and untouched under there. turns out its a 309 ECU.
Alas, a 309 on a 1987 320i will be analogue L-Jetronic, and can't be chipped unlike the later Motronic.
Your only option, should you wish to chip it, is to convert to Motronic 1.3.
scjimbo
Cool ok mate. My car would be a pain in the ass. I'll put a wanted post up. Is it a pain in the rectum to convert to the other ECU?
It is quite a mission. See mattyb's thread:
http://www.e30zone.net/modules.php?name ... 78&start=0
And the Wiki guide:
http://www.e30zone.net/e30zonewiki/inde ... tronic_1.3
And the Wiki guide:
scjimbo
Cheers mate seems quite involved. I might get a quote for my mate whos an automotive sparky
