Hi i'm after some help with my roof, basically the electric roof and electric horseshoe don't work.
I'm in 2 minds whether to convert to manual or fix the electrical side of it, would be nice to have it working on the electric.
Basically I want to know firstly what tests I can do to see which part is faulty, switch, relays, fuses, motors, control board etc?
Am I best chnagin the cheap parts like fuse and relay and switch on dashboard first?
Secondly can I do diagnostic tests, but measuring the voltage with my voltmeter, whilst someones presses the switch and I measure the oltagge going to the connector on the motot?
Am I best off putting some pictures up of the car as it looks to me like the bit where the cable go to at middle of horseshoe somethin is missing.
help with horseshoe and electric roof wanted
matt86
Das_BMW_E30
Is it all connected..? or has the cam sheared off from the top of the motor, with the link bars laying inside the car?
Mine had, bought this kit, problem solved.
http://www.ebay.co.uk/itm/190684305470? ... 1558.l2649
matt86
Cheers mate, think it may have done actually, but shouldn't you still hear or see something turnin even if this is the case?
Das_BMW_E30
Depends if the micro switches are getting current, there's a 'how to' on the wiki..
http://www.e30zone.net/e30zonewiki/inde ... ctric_roof
and this zoner has very recent experience..
Try the technical section. This section is NOT for discussing fooked scrap !
All the freaks who like talking about other peoples fooked scrap hang there
matt86
Cheers mate will post in there.pacerpete wrote:Try the technical section. This section is NOT for discussing fooked scrap !![]()
