Heater Matrix
Ianb
Post Thu Jun 21, 2012 9:55 am
Just my luck, I realised after I fitted the M50 that my heater hoses were arse about face when the valve started knocking, now after a 750 mile trip to Le Mans and back I've got soaked carpets on the psg side and low water level so i guess Brianmoore was right about the wrong flow direction damaging the valve :evil: ! .Anyway I Started stripping off the inlet manifold last night to get at the hoses and have yet to take out the dash to get at the matrix ( and the carpets to dry them LOL) so I only want to do this once and am really nervous of fitting a 2nd hand unit. Has anybody bought a brand new heater matrix? Are they expensive ? Does anyone do pattern parts ? Any info would be much appreciated
Meatballs82
Post Thu Jun 21, 2012 10:15 am
If its non air con I have them in stock - £35 with pipe seals delivered (plastic pipe type)
If its air con - special order only - £70 delivered (aluminium pipe type)
Could do with your reg though just to check accuarcy
**BANNED**
Post Thu Jun 21, 2012 10:20 am
Should be able to slide the heater matrix out without taking the dash out,but as I have not atually swapped a matrix myself I am going on internet lore!
At meatballs price,it hardly seems worth hunting out a s/h unit!
Youth is wasted on the young.
harry_p
Post Thu Jun 21, 2012 10:34 am
this thread will probably be of use
http://www.e30zone.net/modules.php?name ... c&t=222184
cheers,
harry
Post Thu Jun 21, 2012 1:49 pm
Which has failed, valve or matrix? Two entirely separate parts.
As long as a second hand valve doesn't show signs of leakage from the join in the two halves it should be OK.
The whole heater system should be running under a bit more strain after a M50/52 conversion, unless the car is an iS, since you should be running the system at 2 bar instead of 1.4.
Emm3
Post Thu Jun 21, 2012 10:25 pm
I went through 3 used valves before I got fed up and modded one and also replaced the rubber washer inside the valve now does not have the plunger inside so my heaters are always hot but I just turn them off when not required. Also changed the matrix on mine only difficult part is the brake pivot linkage needs to be removed to slide the matrix ou
