Been looking into these guns. They are "gravity fed".
Devilbiss SLG-610 (StartingLine) @ £60-ish
Devilbiss FLG-5 (FinishingLine) @ £100-ish
SLG-610:
Gravity Fed / 4.8cfm / 550ml cup / Requires 5cfm compressor / Recommended to work @ 2.5bar / maximum is 4bar
FLG-5:
Gravity Fed / 9.8cfm / 560ml / Requires 10cfm compressor? / Recommended to work @ 2bar / maximum is 4bar?
What would you choose as these are the guns I am looking to get within 2 weeks time. Need to know what compressor would be recommended as I am using 2K paint from a reputable local paint shop.
I am good with the body work i.e straightness and smoothness of panels and also primer. Just need help with paint guns to go for and compressors to run them.
Help is much appreciated sorry for the longness but just making it clear on what I'm on about! Cheers Guys
