Goose vs S50 installation
goosiegander
- Zonegoose
Just a quick question, for purposes of commisioning and getting up to temp is there a better oil to use?
Its going to be used at running temp for less than a mile and then dropped to flush the old stuff out,
penton08
I used cheap 10/40 for a flush and then in with the good stuff
goosiegander
- Zonegoose
Coolio,
just pm'd Ian with the wiring info request,
plan is to molest the loom into the 4 pot cover asap, gaskets etc will be ordered tomorrow,
moordoor can be attacked following friday or just after if your still up for it?
Will build up the lump ready to go in from below, drop m20, remove from subframe and replace with s50, will swap servo in the next few days and start getting used to that...
Will also relocate teh battery to the boot with the kit that came out of the m3...
Cant think of much else to expidite the process...
penton08
Ask Homo hair or Danthe to sort your loom mate!!! Saves a mega headache
goosiegander
- Zonegoose
While i'm thinking about it is it the standard e30 flexi from master hardline to slave cylinder?
Had a search and didn't see anything, figure the one thats there is damn near brand new...
Could do with a gearbox mount and 328 prop if you have them kicking about Nath?
I need to order some gearbox bush mounts and an oil filter along with a few other bits but the bulk of it is there...
ross_jsy
Diesel oil is good for an engine flush as it is full of detergents, however I'm not sure if I would put it in something like an s50. Also can run into problems with bits of carbon being loosened and blocking up things like hydraulic adjusters.
goosiegander
- Zonegoose
I'm Happy with 10w40 to flush in the 1st instance, regular short interval complete oil changes following that should help.
Filters and g-box mounts ordered, have new center bearing for the prop, damn, i've forgotton the prop donut!
goosiegander
- Zonegoose
Donut ordered,
Sump windage tray removed, SA emmisions blanking plate fitted, Turner motorsport oil cooler line adaptor fitted, aircon pump removed,
Closer and closer...
goosiegander
- Zonegoose
just a thought with oil priming following the pick up change,
Im planning on filling the cooler and lines so far as is possible, can oil be introduced to the filter housing that will make its way down to the pump?
Perhaps a big no-no but the thought just struck me...
PazzaAE86
Just crank the engine loads to make pressure before starting?
Plugs out and crank till the light goes out
goosiegander
- Zonegoose
coolio, pull the fuel relay as well?DanThe wrote:Plugs out and crank till the light goes out
tomislav
GOOSE! When did the s50 conversion start??? I STILL havent got my m20b28 built yet lol.
Sounds like ya moving afst on this one, let me know how it goes cos its my next route after m20b28, but maybe an s54, we'll see!
tomislav
Oh yeah, danthe's wiring loom are the tits, got one made for my mates m52b28, plug and play easyness ftw!
goosiegander
- Zonegoose
Fresh report from Machine shop,
Big end shells look 'brand new' so ARP's wil be fired in shortly.
Jhonno's old wiring loom has pitched up care of Peet.
e46 compact rack adorns the garage floor and I need to send my UJ's off to you Dan (sorry it hasn't happened sooner was waiting on another one to arrive).
just need to solve the oil cooler problem now and the engine can be installed & started -on that note, can i use the stock cooler and the part of the lines that bolt to it?
Idea is just to chop the engine hard lines from the pipes and fit adaptors and some extra pipe with joiners to the turner motorsport fixing if you follow me?
Any pictures available of the e36 m3 oil cooler mounted to the e30 crossmember?
I chopped the crossmember out and replaced it with some tube
Or you can use the M20 cooler with the pipes turned round/tweaked and the flexi's cut and joined to the S50 flexi's
goosiegander
- Zonegoose
Hmmm,DanThe wrote:I chopped the crossmember out and replaced it with some tube
Seems a bit invasive -would the m20 cooler deliver the performance required?
thought i'd snap a pic:
PazzaAE86
That lower cross member is made of tinfoil anyway, that bar is probably alot stronger than original box section.
penton08
The M20 cooler will work fine mate. I have a good guy to make the lines up. A bit of braided line, a few aN fittings= jobbed
Thats my track car, so function over formgoosiegander wrote:Hmmm,DanThe wrote:I chopped the crossmember out and replaced it with some tube
M20 cooler is fine for a general road going car
- Homo Hair
Same size is it not?penton08 wrote:The M20 cooler will work fine mate. I have a good guy to make the lines up. A bit of braided line, a few aN fittings= jobbed
goosiegander
- Zonegoose
Will hold one cooler against the other while dinner is being cooked...Jhonno wrote:Same size is it not?penton08 wrote:The M20 cooler will work fine mate. I have a good guy to make the lines up. A bit of braided line, a few aN fittings= jobbed
Are the m20 cooler lines 1/2" bsp thread if so the following should do...
http://www.ebay.co.uk/itm/Mocal-90-Deg- ... 3f11941f62
http://www.ebay.co.uk/itm/Mocal-Moquip- ... 2ebafb47ac
Then some adapter to the 10an fittings on the oil housing and we're there... i think...
- Homo Hair
BMW oil coolers are an odd thread.. I've not yet heard of someone being able to match the threads to a sizing.
ajay
Jhonno is correct, i tried to get fittings for a m5 oil cooler no one could match them. so( think automotive) sold me some alloy fittings to get welded on to the ends of the cooler,which worked a treat and still fits in the orig e30 position.
goosiegander
- Zonegoose
Cooler to one side for the moment,
Fooking servo/MC combo! -not at all happy with making up a spacer:
http://www.e30zone.net/modules.php?name ... ge&start=0
Well not perminantly anyway, do we know if the WMS calipers can be taylored to the displacement of a larger MC?
crossie
@goosiegander
you not fitting the S50 into your m3?
goosiegander
- Zonegoose
No, dramatic change of plans, S14B25 ala Sport evo spec.crossie wrote:@goosiegander
It'd be rude not to,
Pictures taken of sump'd and ARP'd engine shortly...
crossie
photo of where you have added you new oil return to sump would be good.
get some of your e30 m3 photos up as well!
goosiegander
- Zonegoose
Oil return is being tacked onto the dipstick dude,crossie wrote:photo of where you have added you new oil return to sump would be good.
Will hopefully be able to update the M3 thread in a weekend or two
goosiegander
- Zonegoose
Penton... Its over to you!
goosiegander
- Zonegoose
Lump prior to being dropped at BBB:
(e34 sump level sensor gasket part 12611277129)
keri-WMS
The three sizes of T20 caliper we offer are:goosiegander wrote:...do we know if the WMS calipers can be taylored to the displacement of a larger MC?
1.25"/1.25" piston = 87.5% of OEM area (the default on our E30 kits)
1.38"/138" piston = 106.6% of OEM area
1.62"/1.75" piston = 159.2% of OEM area
If you're going for a slightly larger master cyl than standard then the 1.38/1.38 size is a safe bet I expect - the largest one is huuuuge.
Das_BMW_E30
Hi, did you use standard bearings for big ends and mains..?
goosiegander
- Zonegoose
Yes indeed, only the big end bolts were uprated to ARP'sDas_BMW_E30 wrote:Hi, did you use standard bearings for big ends and mains..?
goosiegander
- Zonegoose
Referance for standard airbox:
borrowed from Henry
borrowed from Henry
