whats worth keeping
pipework
just a quick one
i have been given the chance to strip any bits i want off of a 316 e36 that's going to be scrapped. apart from the steering rack what other parts will fit my e30 and is worth getting off this old dog??
thanks guys
thanks guys
Barx325i
if the window switches are the LED type, they're worth about as much as the rest of the car
Ooko
Those window switches! ahahhaahaBarx325i wrote:if the window switches are the LED type, they're worth about as much as the rest of the car
mrLEE30
^^ what is a LED window switch?
Barx325i
one with LED illumination instead of the usual incandescent bulb. Super mint
pipework
ill have a look. anything else??
Barx325i
If it's had a new cam/followers very recently, they're worth grabbing
any change from the ashtrays and scrap the rest !
+ a yard full of scrap turds
polsta
you just aswell strip any parts that are nice and not damaged to keep as spares, all little interior trim bits,switches, instrument cluster is handy to have spare, gaitor, gear knob,center console,under steering panel (£25) etc are all worth having if nice,can never have enough spares,tool kit ? lights front and rear, all sorts id take, why not
It is an E36polsta wrote:you just aswell strip any parts that are nice and not damaged to keep as spares, all little interior trim bits,switches, instrument cluster is handy to have spare, gaitor, gear knob,center console,under steering panel (£25) etc are all worth having if nice,can never have enough spares,tool kit ? lights front and rear, all sorts id take, why not
Duke137
Landfill.
Kedge
You implying Polsta didn't read a thread proparly?pacerpete wrote:It is an E36polsta wrote:you just aswell strip any parts that are nice and not damaged to keep as spares, all little interior trim bits,switches, instrument cluster is handy to have spare, gaitor, gear knob,center console,under steering panel (£25) etc are all worth having if nice,can never have enough spares,tool kit ? lights front and rear, all sorts id take, why not
taking anything off the sorry turd will reduce your rewards when it crosses the bridge,
I personally would fill the fuel tank with the hose pipe and send it off to china
I was initially suprised that he hadn't mentioned removing the dash and carpets and covering eveything in sight in FERTANKedge wrote:You implying Polsta didn't read a thread proparly?pacerpete wrote:It is an E36polsta wrote:you just aswell strip any parts that are nice and not damaged to keep as spares, all little interior trim bits,switches, instrument cluster is handy to have spare, gaitor, gear knob,center console,under steering panel (£25) etc are all worth having if nice,can never have enough spares,tool kit ? lights front and rear, all sorts id take, why not
Duke137
After all you can never hacve too many E36 toolkits in your shed
harry_p
I need as offside foglight bracket and a pair of fogs if you can be bothered to remove them.
Or if it's a proper poverty spec model i'd take a pair of foglight blanks and the single button foglight switch.
If its an early car with a quiet, well looked after m40 it might be worth £50 to someone if you can be arsed to remove it.
cheers,
harry
harry
walrus1968
pacerpete wrote:I was initially suprised that he hadn't mentioned removing the dash and carpets and covering eveything in sight in FERTANKedge wrote:You implying Polsta didn't read a thread proparly?pacerpete wrote: It is an E36
KEEPING MY "BLURRED PIXELS" TO THE MAX !!!
