316i anti roll bar
mikeyh
Mon Jun 11, 2012 7:03 pm
Hi
Does anyone know where i can get a front anti roll bar for my 1990 316i.
Mines snapped, i've looked on ebay, theres one on but it says fits all models. Is this right?
cheers
Mike.
johnl320
Mon Jun 11, 2012 7:07 pm
A good upgrade is to fit a thicker one from a 325i or 318is, also if yours is a saloon it won't have a rear rear at all being a 316i so you could fit a rear one as well, both will be available on here and probably won't cost much
johnl320
Mon Jun 11, 2012 7:08 pm
Post in the wanted section and I reckon you will have a reply within half an hour :D
All front ARBs, except M3, will fit your car as long as they are fitted with the appropriate rubber bush, but the thickness of the bars varies.
Put up a post in 'parts wanted' on here.
mikeyh
Mon Jun 11, 2012 7:10 pm
Thanks for quick reply.
The one i've seen is from a 325 tourings so should be ok then.
I'll get it bought.
Barx325i
Mon Jun 11, 2012 7:20 pm
the touring front arb is generally 21mm (unsure there) so make sure you get the associated bushes..
good going snapping one though, you must be driving it as bmw intended.
watching ebay, they're just not selling, so try pick up a set, a rear arb is definitely worth fitting, but you don't need the thicker rear, unless you feel it's necessary
johnl320
mikeyh wrote:Thanks for quick reply.
I'll get it bought.
As long as it comes with the mounting bushes or buy new.
mikeyh
Mon Jun 11, 2012 7:23 pm
Barx325i wrote: good going snapping one though, you must be driving it as bmw intended.
I bought the car on saturday and decided to look for broken bits today lol :mad:
Mon Jun 11, 2012 8:06 pm
i have a good one from a touring with the bushes .sent you a pm.
Jones
Mon Jun 11, 2012 11:38 pm
Best mod I've done to my 316i was the 325i ARB's with all new bushes. The front made the best difference, the rear made it easier to pop the back out :-D
1994 E34 525i sport - Sold
1991 E30 316i LUX 2 dr - soon to be 318is
Tue Jun 12, 2012 12:00 am
i have a touring rear arb for sale also :D
