Rear damper top mount bottom washer
loogie
I have read a post which mentions a bottom washer on the rear damper shock absorber top mount, the top mount has recently failed, my car is missing this bottom washer, is it the same shape and size as the top washer?
Grrrmachine
- E30 Zone Wiki / Team Member
http://www.realoem.com/bmw/showparts.do ... g=33&fg=45
You're comparing part 6 with part 12. Different part numbers = different parts, unfortunately.
loogie
Does that screw into the top of the protection tube 5? If that is the case then I already have that part! I have destroyed two top mounts from GSF one after a couple of months and this one after only a couple of weeks?!! Surely I didn't get two faulty top mounts?
loogie
Looking at the diagram again I may be missing part 4!
Grrrmachine
loogie
Thank you. Will ask GSF for one
rich318i
does anyone use part 10. the gasket or not bother?
loogie
Mine doesn't have part 10 don't think it is vital!rich318i wrote:does anyone use part 10. the gasket or not bother?
I have bought a couple of spreader washers and the E46 convertible top mount, which seems considerably stiffer. Happy Days! Thanks for the tips guys!
harry_p
The washers are only £1.50ish from BMW, one on my e36 rusted through the middle and let the damper push the rubber all the way out of the mount, and through the boot carpet!
cheers,
harry
harry
hennabm
I used part 10 but I don't think they're vital.
If in doubt, a smear of silicone sealer or similar will do just as well to seal the mounting.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
