Anybody know what the ratio is on a 320i Touring, J reg should be? LSD?
Car is under the weight of a VW atm.. So can't check it
320 Touring Manual Diff
- Homo Hair
be a small case 4.1 iirc
- Homo Hair
non LSD
Templ8e30
YupJhonno wrote:be a small case 4.1 iirc
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Simon
Small case?
I removed a large case 4.10 from my 320i touring, which was also a manual.
There is a small chance it could be an LSD though, only way to find out is to turn it and find out!
- Homo Hair
Davetouring had a small case one on his..
oze30
whats the difference between small and large case diffs? Would they interchange? To check for LSD, you jack the rear up and turn one wheel... if the other turns teh same way it's an LSD?
- Homo Hair
small case diff is smaller...
and not as strong
and not as strong
Simon
Yes that's right, if the other wheel turns in the opposite direction, then it's an open diff.oze30 wrote:whats the difference between small and large case diffs? Would they interchange? To check for LSD, you jack the rear up and turn one wheel... if the other turns teh same way it's an LSD?
